Old 03-14-2016, 07:53 PM   #1
Are you feeling lucky?
If it's the factory-original finish with the linear polyurethane 2-part clear coat, it should be extremely resistant to pretty strong solvents, even including acetone, such as lacquer thinner or non-chlorinated brake parts cleaner.
Using anything with acetone would take the old crusty adhesive off in a hurry.
If you have a cheap respray, however, you'll quickly damage your finish and have color transfer onto the towel you within seconds of applying an acetone-laden solvent. This would be very bad. A milder solvents either won't work at all, will require extended dwell time, and/or mechanical agitation (which is another issue if there is dirt in the old adhesive, as it can get scoured into the paint and cause many scratches). There are a few different products out there often recommended for things like removing tar from paint, which could work ok.
Hope that helps, and best of luck.
2001 Boxster
Old 03-15-2016, 02:36 AM   #2
Xpit77's Avatar
Be careful on what you use. I tried some of the products listed here and I damaged the clear coat. Took it to a Body shop and had it buffed out.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
