Old 02-28-2016, 10:06 AM   #1
I believe there is a weep port at the water pump in about that location,
when the seal is going it first goes out there, then tru seal into engine, killing engine.
Stop driving it, and check it out...
Sassmatt72 is offline   Reply With Quote
Old 02-28-2016, 10:51 AM   #2
UnBoxed
Thanks for the feedback. My previous posts didn't post but this one did. Planning on taking it to the mechanic but just a bit panicked. Dreading the bill.
unboxed is offline   Reply With Quote
Old 02-28-2016, 12:19 PM   #3
still plays with cars...
BoxsterSteve's Avatar
I did mine at home. If you can half way turn a wrench, it's a pretty easy job.
Lots of step by step DIY instructions here and elsewhere on the web.
Six speed 2000 Boxster S
Old 02-28-2016, 02:33 PM   #4
UnBoxed
This is really helpful! Thanks a bunch. I think my problem with posting to the forum was my iphobe browser, chrome. It didn't seem to actually submit. Safari works fine. Sorry if it seemed I was bashing the forum.
I just need a lift now. It looks straight forward. It seems odd that it is leaking from the back part of the engine almost immediately when I refill the reservoir. Could it be a hose? Where does the coolant go immediately after the reservoir? It's like it is draining and running to the lowest point of the "skid plate" and then to the floor. Thanks again.
Old 02-28-2016, 05:27 PM   #5
No lift needed... I did mine while it was perched on 18" tall stands. Lots of clearance.
As for where it's leaking from, lift the car and stick yourself underneath while a volunteer fills the reservoir.
