Old 02-17-2016, 04:35 AM   #1
quick question. axles for 5 spd vs 6 spd
if i swapped out my 5 speed manual for a 6 speed manual would i need to swap the axles and hubs?
1998 boxster base.
compinsating is offline   Reply With Quote
Old 02-17-2016, 05:22 AM   #2
Yes. 5 vs 6 speed axles. The 6 cv joints are much beefier than the 5 speed and the 6 speed are longer because the 6 speed sits farther back. The 6 speed axle also wound not fit inside the 5 speed upright without milling the upright to fit the massive 6 cv joint.
Woody
Old 02-17-2016, 05:27 AM   #3
Thank you, very alpreciated.
Old 02-17-2016, 12:29 PM   #4
Why would you do that?
Most people hardly ever use 6th gear...
Tcar is offline   Reply With Quote
Old 02-17-2016, 02:12 PM   #5
strength, doing an engine swap. just wanted that tid bit of info since i couldn't seem to find it online.
Old 02-21-2016, 01:40 PM   #6
Quick follow up question. Are the rotors and calipers the same between the two cars?
Old 02-21-2016, 03:58 PM   #7
Steve Tinker's Avatar
No....
There is a big difference between the base & S brakes and calipers and also IIRC the hand brake shoes.
Its difficult (expensive) to retrofit S brake assemblies onto the base model at the rear. The fronts are much easier.
2001 MV Agusta F4.
Old 02-21-2016, 04:29 PM   #8
http://986forum.com/forums/performance-technical-chat/53067-pictorial-differences-between-base-s-model-boxster.html
Woody
Old 02-22-2016, 07:54 AM   #9
Thanks guys.
Old 02-22-2016, 08:00 AM   #10
The Radium King's Avatar
if you want to keep your rear 5-speed wheel carriers (brakes, suspension, etc.) I am pretty certain that you can fit the 6-speed hub in the 5-speed wheel bearing/carrier. otherwise i am pretty sure the 6-speed axles won't fit in the 5-speed hub. note that you also have to change the slave cyl and shift cables/linkages.
edit - reread novas post. I know it works the other way (5 speed hub in 6-speed wheel bearing/carrier) but didn't think about clearance required for the larger cv joint. dunno there. unless you can figure out a way to get the outer cv joint off the axle (don't think possible).
