Old 11-13-2015, 01:17 AM   #1
mariosp's Avatar
Send a message via Skype™ to mariosp
Fuel additives
Hello!
I would like to know your feedback regarding the fuel additives and if there are brands which are porsche approved ? or any other ranking list?
What are the pros and cons?
thanks
MArios
Marios
Porsche Boxster '04 weekend car
BMW X5 M sd '07 daily car
mariosp is offline   Reply With Quote
Old 11-13-2015, 03:11 AM   #2
mikesz's Avatar
I live in the NE USA. The car is driven weekends and sometimes during the week but mostly pleasure driving. Doesn't get driven in the winter but in the spring I change my oil and put in a can of seafoam additive. I have read Chevron gas is good to use too because they put cleaning additives in their gas.
99 Porsche Boxster
Old 11-13-2015, 04:43 AM   #3
my Box is only driven in summer season, so it sits in the garage over the winter, and sometimes also in summer. 2014 i have driven it for 1.300 Km. This spring i noticed a very loud noise from the fuel pump. Went to the car parts shop and bought an injection cleaner which also cleans fuel lines and everything related. Worked great. Fuel pump is calm now.
Product was this: LIQUI MOLY - Motorenöle, Additive, Autopflege - Produkte - Injection-Reiniger
Don't know if it's available in Cyprus
Regards, Markus
Old 11-13-2015, 04:43 AM   #4
The techron by chevron is good stuff to help clean the fuel system. I run it through once or twice a year. As far as any additives that guarantee hp upgrades? Snake oil.
Old 11-15-2015, 10:22 PM   #5
Regards, Markus
That is the same my local independent Porsche mechanic uses. I use once yearly as well.
seawind is offline   Reply With Quote
Old 11-16-2015, 07:56 AM   #6
1998 Boxster Owner
Regards, Markus
It's available on Amazon here in the U.S. - Thanks for the suggestion!
Benitom is offline   Reply With Quote
Old 11-16-2015, 08:05 AM   #7
schnellman's Avatar
+1 Techron
I've used Techron for five years and swear my Box loves it.
Old 11-16-2015, 08:30 AM   #8
There Is No Substitute.
rick3000's Avatar
I occasionally add some Techron fuel system cleaner. The Porsche dealer actually recommended I use it every few months after a carbon build up on my idle control valve caused some issues.
Old 11-16-2015, 10:07 PM   #9
nieuwhzn's Avatar
Techron about every 1000 miles, translates to every 5th fill up for the boxster. Use it for all our cars nowadays. Buy it in bulk at Costco.
nieuwhzn is offline   Reply With Quote
Old 11-17-2015, 05:42 AM   #10
I use the Chevron Fuel System Cleaner with Techron PRIOR to every oil change. So, about 300-400 miles before the oil change. Add to tank, run low-low, refuel, then change oil.
Prior to winter hibernation Mid Oct till mid March), I use StaBil fuel stabilizer at 1 ounce per 2.5 gallons fuel.
Old 11-17-2015, 06:21 AM   #11
CatAClean
I have started using CatAClean by Mr Gasket, works great, had a OBDII fault on my 06 Jeep Liberty over a year ago, added CatAClean fault gone. Use in my 02 Bosxter S car runs great.
eallga72 is offline   Reply With Quote
Old 11-17-2015, 06:27 AM   #12
98 Arctic silver 986
tommy583's Avatar
I've used BG44 in my Jeep Cherokee. I can say it really made a difference. I was actually surprised at how well it worked. I haven't used it in the Boxster though.
Old 11-23-2015, 01:05 PM   #13
mariosp's Avatar
thank you all for your replies
Which one Techron
I found 65740.. 67740..
Could you recomend any other for diesel engine?
Marios
Old 11-26-2015, 01:05 AM   #14
Saw this on the net:
To meet your specific needs, there are two sizes of TECHRON® Concentrate Plus:
*20 oz. #65740 - Treats up to 20 gallons of fuel and is designed for larger cars, light-duty trucks and sport utility vehicles.
*12 oz. #67740 - Treats up to 12 gallons of fuel and is designed for smaller cars.
fredd5r is offline   Reply With Quote
Old 11-26-2015, 06:02 AM   #15
The instructions on the techron says to add when tank is low. Is that 1/4 tank or less?
Old 11-26-2015, 07:25 AM   #16
Short answer is yes but more important is to look at how many gallons one bottle can treat. For our cars we need the 20 oz bottle.
Its best to use when you're filling up and pour the bottle in first before pumping the gas in. The force of the fuel being pumped in will mix the Techron in the gas tank.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 12-17-2016, 06:36 AM   #17
Lew
So Blessed!
Lew's Avatar
I read this on another post titled "Gas Treatments". What could possibly be the crud?
Treatment is a good thing, but use a good one such as Techron, and plan on changing your oil within one to two tanks of gas after the treated tank. The oil will collect some crud knocked loose by the treatment.
Lew is offline   Reply With Quote
Old 12-17-2016, 07:40 AM   #18
Ciao's Avatar
Many have had great success with fuel additives; interestingly my Boxster manual states not to use any fuel additives. So, I am using Stabil as I winterize the Box but am hesitant to use fuel additives when I take the Box out of storage during the Spring/Summer/Fall
5280 Cruising @High Altitude
Seal Gray & K&N Filter
Old 12-17-2016, 07:11 PM   #19
The best gas additive for idle or short-term stored cars is Stabil. If you've ever had to purge gelled old gas from a Porsche you will remember this recommendation. Those insoluble balls of gell stick and clog all over the system and get dislodged at intervals. The good thing is that they eventually arrive in the filter basket of an injector. Usually #4 !
Old 12-18-2016, 02:59 PM   #20
"50 Years of 550 Spyder"
10/10ths's Avatar
What was posted above is correct...
...you put the fuel additive in on an empty tank, while at the gas pump, and then fuel up your vehicle. You also want to do this a couple of tanks immediately before an oil change.
The stuff will get by the rings and into the oil a little bit, so you want to change that oil.
Techron is a good all-a-round fuel system cleaner. Sta-Bil is a good all-a-round storage protector.
If you have a clogged injector, or want to really clean up the valves and such, "Sea Foam" is incredibly effective. I have personally witnessed "Sea Foam" clearing multiple vehicle fueling issues.
