Old 10-09-2015, 01:25 PM   #1
Electrical issues!!! Help?? please? :(
00' Box 70k miles Long time lurker first post
1.) Overhead and door lamps inop, changed bulbs checked fuses. Not in any positio
2.) Rear defrost inop
3.) Central door locking switch inop
Interiors and central locking all went at same time when my keyfob stopped working.
HELP
Johnguelff is offline   Reply With Quote
Old 10-09-2015, 02:01 PM   #2
I am my own mechanic....
Timco's Avatar
Look under drivers seat. Any sign of moisture? Likely immobilizer got wet. There are drain plugs under the top storage area and under the frunk hood back by the battery. They get clogged easily and water gets in.
'08 VW Touareg T-3 wife's car
Old 10-09-2015, 02:10 PM   #3
JayG's Avatar
Do both rear fog lights work?
You are slipping Tim...
Old 10-09-2015, 04:38 PM   #4
X2
I'd even take the immobilizer apart to see inside it. I've seen a few boxsters that had wet immobilizers and there was no obvious signs of moisture on the outside.
Woody
Old 10-09-2015, 06:22 PM   #5
If your immobilizer is not wet, remember that a failing ignition switch does weird crap as well....
radio, A/C windows.
