09-25-2015, 09:06 AM
#1
Got clipped in a parking lot yesterday
Can someone let me know if the small damaged section can be replaced alone, or does the whole headlight assembly need to be replaced?
09-25-2015, 09:08 AM
#2
Pretty sure the corner piece is separate but make 'em pay for a whole headlight
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
09-25-2015, 09:10 AM
#3
Jäger
300K Mile Club
Reason: Added link for part
09-25-2015, 09:40 AM
#4
Thanks! Is this something a body shop should do, or is it pretty straightforward to replace?
09-25-2015, 10:10 AM
#5
It just snaps on. Takes about 30 seconds to slide the headlight out and replace.
09-25-2015, 10:41 AM
#6
I found this youtube showing the removal of the whole headlight assembly, which is pretty cool!
https://www.youtube.com/watch?v=D65x8G1f6AI
But I am still unclear about how to replace the corner section. Once the assembly is out, does that piece just unclip?
09-25-2015, 10:44 AM
#7
Yes, it just has 3 small clips.
09-25-2015, 10:56 AM
#8
09-25-2015, 11:22 AM
#9
Thanks again! I appreciate the help.
09-25-2015, 11:41 AM
#10
That looks to be the corner unit that has a hole for the headlight washer. Same process but different part.
2001 Boxster S - Midnight Blue Metalic
09-25-2015, 11:55 AM
#11
This one, right?
2001 Porsche Boxster Base Convertible - Exterior Trim - Page 1
The youtube I found earlier might have mentioned this, but I have no audio at work.. What size ratchet is used to loosen the headlight assembly?
09-25-2015, 01:46 PM
#12
98 Arctic silver 986
5mm i think.
09-25-2015, 02:49 PM
#13
Originally Posted by Finnegan
That is the correct part.
09-26-2015, 06:46 AM
#14
Project Addicted
That blows!!!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
09-26-2015, 12:32 PM
#15
Lapis Blue 03 Boxster S
09-26-2015, 11:27 PM
#16
Finnegan, I have set of those corners. When I bought a used set of headlights(Litronics) for my car it came with those corners, but my car was without washers. I ended up buying new set. I think I broke one of 3 tabs on one side, but don't remember which one. Let me know if you are interested.
ArmenT.
09-28-2015, 10:16 AM
#17
Hi Armen,
Thank you, yes, I am interested! I need the driver's side. Could you check to see if that is the side with the broken clip?
09-28-2015, 10:18 AM
#18
Thanks for the Suncoast link, Tony!
09-28-2015, 05:51 PM
#19
You are in Oregon, contact Sunset Porsche, they have lower prices most of the time.
Jäger
300K Mile Club
09-29-2015, 10:52 PM
#20
Finn, PM sent to you with some photos.
