Old 09-25-2015, 08:06 AM   #1
Finnegan's Avatar
Got clipped in a parking lot yesterday
Can someone let me know if the small damaged section can be replaced alone, or does the whole headlight assembly need to be replaced?
Old 09-25-2015, 08:08 AM   #2
Pretty sure the corner piece is separate but make 'em pay for a whole headlight
John or J.J. - But I answer to most anything~
*2000 Honda Accord 4DR V6 - 220K*
http://986forum.com/forums/show-tell-gallery/54328-boxsterls376-introduction-ls3-conversion.html
BoxsterLS376 is offline   Reply With Quote
Old 09-25-2015, 08:10 AM   #3
Jager's Avatar
The corner lens is a separate piece.
http://www.pelicanparts.com/catalog/SuperCat/1047/POR_1047_BDYEXT_pg1.htm#item2
Jäger
300K Mile Club
Old 09-25-2015, 08:40 AM   #4
Finnegan's Avatar
Thanks! Is this something a body shop should do, or is it pretty straightforward to replace?
Old 09-25-2015, 09:10 AM   #5
It just snaps on. Takes about 30 seconds to slide the headlight out and replace.
Old 09-25-2015, 09:41 AM   #6
Finnegan's Avatar
I found this youtube showing the removal of the whole headlight assembly, which is pretty cool!
https://www.youtube.com/watch?v=D65x8G1f6AI
But I am still unclear about how to replace the corner section. Once the assembly is out, does that piece just unclip?
Old 09-25-2015, 09:44 AM   #7
Yes, it just has 3 small clips.
Old 09-25-2015, 09:56 AM   #8
Old 09-25-2015, 10:22 AM   #9
Finnegan's Avatar
Thanks again! I appreciate the help.
Old 09-25-2015, 10:41 AM   #10
jpc763's Avatar
That looks to be the corner unit that has a hole for the headlight washer. Same process but different part.
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 09-25-2015, 10:55 AM   #11
Finnegan's Avatar
This one, right?
2001 Porsche Boxster Base Convertible - Exterior Trim - Page 1
The youtube I found earlier might have mentioned this, but I have no audio at work.. What size ratchet is used to loosen the headlight assembly?
Old 09-25-2015, 12:46 PM   #12
98 Arctic silver 986
tommy583's Avatar
5mm i think.
Old 09-25-2015, 01:49 PM   #13
jpc763's Avatar
Originally Posted by Finnegan View Post
This one, right?
That is the correct part.
Old 09-26-2015, 05:46 AM   #14
Project Addicted
jcslocum's Avatar
That blows!!!
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 09-26-2015, 11:32 AM   #15
amagalla's Avatar
Suncoast has them a bit cheaper:
Suncoast Porsche Parts & Accessories Triangle Headlight Trim
Tony
Lapis Blue 03 Boxster S
Old 09-26-2015, 10:27 PM   #16
ArmenT's Avatar
Finnegan, I have set of those corners. When I bought a used set of headlights(Litronics) for my car it came with those corners, but my car was without washers. I ended up buying new set. I think I broke one of 3 tabs on one side, but don't remember which one. Let me know if you are interested.
ArmenT.
ArmenT is offline   Reply With Quote
Old 09-28-2015, 09:16 AM   #17
Finnegan's Avatar
Hi Armen,
Thank you, yes, I am interested! I need the driver's side. Could you check to see if that is the side with the broken clip?
Old 09-28-2015, 09:18 AM   #18
Finnegan's Avatar
Thanks for the Suncoast link, Tony!
Old 09-28-2015, 04:51 PM   #19
Jager's Avatar
You are in Oregon, contact Sunset Porsche, they have lower prices most of the time.
Jäger
300K Mile Club
Old 09-29-2015, 09:52 PM   #20
ArmenT's Avatar
Finn, PM sent to you with some photos.
