Old 09-18-2015, 11:19 AM   #1
Have tire patched at Porsche indy for $60 or at a regular ole tire place for less?
My Boxster's tire has a tiny leak that slowly - very slowly - leaks air. I notice it getting lower every two weeks or so.
The indy says they patch it from the inside, which he claims is better than regular tire places that will likely patch from the outside.
Thoughts?
new2bxstr is offline   Reply With Quote
Old 09-18-2015, 11:34 AM   #2
steved0x's Avatar
I have had tires patched at tire kingdom and they dismount the tire and patch it from the inside, and remount, the cost is usually barely any higher than the cost for mounting and balancing a tire. Maybe $20'ish?
Steve
Old 09-18-2015, 11:46 AM   #3
go somewhere else, i paid about 170 for new rear bridgestone tire. 20 bucks inside patch.
nicecar is offline   Reply With Quote
Old 09-18-2015, 12:10 PM   #4
JayG's Avatar
Do not run a tire that has been plugged, only internal patch.
Are you sure the tire is leaking from the tread? I had 2 slow leaking tires on my 996 and it turned out to be the bead seal.
I ended up taking them to a wheel repair place and they fixed the wheels. They are 3 piece with chrome barrels.It is not uncommon for chrome wheels to leak at the beads
In any case, $20-$25 is normal to patch a tire. Some of the tire stores here will do free patching with a coupon from their website. If you have Express Tire, have a look
Old 09-18-2015, 12:18 PM   #5
Beginner
Jamesp's Avatar
I had a hole ( on a brand new tire :troll patched at discount tire. They use a piece of rubber shaped like the stem of a wine glass, with the base being the patch. They removed the tire, prepped the hole area put the "stem" into the hole, glued the crap out of it, pulled it through and pressed the patch down with pressure. Looked like a high quality patch. Price - free.
2003 S manual
Old 09-18-2015, 12:32 PM   #6
JayG's Avatar
+986
That is the correct way to do it
A plain plug will not hold up on a high performance car and can be dangerous
Old 09-18-2015, 07:26 PM   #7
+986
I put a plain plug on my rear tire, cost me $0.50, and it lasted the life of the tire, over 30k miles.
Old 09-18-2015, 07:44 PM   #8
Same here and I've done several on my cars. I always have it with me on long trips. The proper way is to use the patch/plug combination but not many tire repair shops have them.
However, you shouldn't be doing track days with a patched or plugged tire. This is where conditions exceeds the limits of the plug.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 09-18-2015, 08:41 PM   #9
amagalla's Avatar
If you have an America's Tire, or Discount Tire near you, they'll generally do it for free. They give awesome customer service in order to get the repeat business.
Lapis Blue 03 Boxster S
Old 09-19-2015, 05:28 AM   #10
Beginner
Jamesp's Avatar
I have frequently put in plugs and have also run tires many, many miles on them without incident, but that is on SUVs or sedans that are in relatively light service from a tire perspective. If you read the packaging they are not for automotive use. I'm sure there is reasoning based in litigation for that, and the litigation is based on failure rate. I agree with Jayg that a much better repair is an inside patch, and the best is plug and patch.
2003 S manual
Old 09-19-2015, 05:36 AM   #11
schnellman's Avatar
Sounds like your indy is taking a hint from the dealership. I got a tire plugged and patched from the inside at my Tire Rack approved dealer for $15. Didn't have a problem for the rest of the life of the tire.
Old 09-19-2015, 11:29 AM   #12
Most of the national chains will patch from the inside. I've been charged anywhere from $10 - $35 over the past 25 years.
token 00 is offline   Reply With Quote
Old 09-19-2015, 12:52 PM   #13
lkchris's Avatar
No tire manufacturer approves externally installed plugs.
No tire shop concerned about its liability and its customers does either.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 09-19-2015, 02:04 PM   #14
Top_Ramen's Avatar
Get it done right the first time. Take it to an approved tire place to have it internally patched/plugged(should be between $12-25), rather than being out driving around constantly worrying about a plug falling out.
Problem with plugging it yourself, is if it falls out, you're left with a bigger hole than you initially started with....
Top_Ramen is offline   Reply With Quote
Old 09-19-2015, 06:01 PM   #15
I don't track my car. I plug on cattle trailers, and our 3/4 ton and 1 ton pickups and the plugs have not failed us. So, I'll keep doing what I'm doing.
Old 09-19-2015, 06:07 PM   #16
JayG's Avatar
A cattle trailer or pickup is not a Boxster. If you drive hard at all its much more stress on the tires .
Old 02-12-2018, 04:47 PM   #17
Wangta's Avatar
Anyone know if this is "patched correctly"?
2001 Porsche Boxster S Tiptronic
Wangta is offline   Reply With Quote
Old 02-12-2018, 05:01 PM   #18
Is it holding air? Probably will do you just fine on the Interstate.
In these parts, the closest and best tire place is Discount Tire. Nice guys do good work. They especially are nice if you are a regular customer (they can tell from your computer file.) Makes me feel a little guilty that I bought a set of Riken tires from Tire Wreck. But they were cheap, made by a subsidiary of Michelin, and get great reviews. Their cheaper than motorcycle tires.
2001 Boxster
2007 Toyota Highlander
Old 02-12-2018, 05:10 PM   #19
Wangta's Avatar
Yep holds air fine - and we don't drive it super hard. I just didn't know if it was the "right" way with the plug sticking out, and the base glued, etc.
Old 02-12-2018, 05:30 PM   #20
No way to tell. The "right way" is patched from the inside, but there are patch/plug combinations, so in that instance, you'd still see the plug from the tread side.
