Old 09-11-2015, 10:07 PM   #1
Remote lock question (2003 S)
I have a 2003 S and am confused about the remote lock/unlock. Sometimes when I lock the doors I get a chirp and sometimes I don't. I don't do anything different, get out, press the lock button, that's it.
Any ideas?
Thx,
Bob
bobs_boxster is offline   Reply With Quote
Old 09-11-2015, 10:42 PM   #2
The "chirp" means something isn't closed or locking correctly (usually the center console lid).
If it's locking and arming properly, it won't make that sound.
Old 09-12-2015, 03:46 AM   #3
JRide's Avatar
I just learned something new. Didn't know the center console lid locks with the remote!
JRide is offline   Reply With Quote
Old 09-12-2015, 08:16 AM   #4
Sorry, bad wording. The lid doesn't lock with the remote, but the central locking system will see an error and "chirp" if it's not fully closed.
Old 09-12-2015, 01:04 PM   #5
PaulDash's Avatar
Have the same problem. Durametric says lock sensors in frunk and trunk, both doors, and central console lid work fine. Still, I get the chirp.
It started when I put in an aftermarket Becker radio. Its alarm light flashes when car is locked, but could it be the little cable in the back needs to be grounded (or at +12V)?
Past: 944 NA white '86
Present: 986 black '98
Future: 959
PaulDash is offline   Reply With Quote
Old 09-12-2015, 09:31 PM   #6
Thanks all for the stuff to check, I'm betting that it's the center console on my car.
Thx again, bob
Old 09-13-2015, 06:59 AM   #7
Chuck W.'s Avatar
There is a ground wire that is attached on the left side of the frame that the radio slides into. Disconnect this wire and you should be good.
Take a look at the right side of the below photo. You will see where the ground wire is attached.
And... it locks the gas lid also.
1995 Porsche C4 Cab
Old 09-13-2015, 03:05 PM   #8
PaulDash's Avatar
DISCONNECT? Really? I was sure that the point was to keep it connected. So how does that work? I'll try it tomorrow if I can find the radio keys.
Future: 959
Old 09-14-2015, 08:14 AM   #9
Yeah disconnect it. If you leave in there you may find that this grounds and sets alarm off randomly. Designed so that if you park with roof down and someone tries to extract radio it sets alarm off.
Alternative is to stick felt to side of radio , per the radio that will have come out of car, think it's on LHS of radio.
andys320 is offline   Reply With Quote
Old 09-15-2015, 05:30 PM   #10
PaulDash's Avatar
Thanks guys.
Took the radio out today, disconnected and isolated the cable, and I still get the chirp. What else to check?
Future: 959
