Old 06-30-2015, 06:51 PM   #1
Artist, 986S tinkerer
NewArt's Avatar
Is this sound similar to blowing across a Coke bottle? I have this at about 25-30 mph, changed the fuel line vent valve and... no change. Don't know what it is. Guess I'll try tape, it's cheaper! What article did you see for the tape experiment?
Old 07-01-2015, 07:23 AM   #2
Drives with Scissors
TMass's Avatar
Yes: it is just like blowing across a coke bottle; usually at slow speeds, 2nd or 3rd gear at 2600 to 3400 RPMs and only if your applying gas. I found a couple of threads here and at ReenTech that addressed "Gsd Cap Noise". My vent is to the right of the gas cap door when it is open...there is a gap that shows the rest of the fill compartment. Some stuck a sponge in...I went with a piece of duct tape with a couple of small nail holes I put in so there is some venting. The correct solution is to replace a control valve for the charcoal filter but i understand that to cost about $500. I'll stick with the tape solution for now.
2002 Boxster S Arctic Silver
TMass is offline   Reply With Quote
