06-05-2015, 09:19 AM
X GI
The stuff works
I've used sea foam on lots of cars so I have experience..Put 8 oz in the tank (full tank of gas) and she runs much smoother! This is before I tear open the engine bay and remove the throttle body for a complete cleaning..
Daily Drivers:
2013 Passat SE
2001 RX300
1999 Boxster
06-05-2015, 09:24 AM
You should change oil soon after to get rid of crap that gets into the oil
06-05-2015, 09:52 AM
I would not put that crap in my car.
They have done a few before / after videoes with hardly any change.... Just another snake oil
06-05-2015, 09:58 AM
I don't think that is a Porsche approved fluid.
06-05-2015, 10:00 AM
I am my own mechanic....
Nope........
'08 VW Touareg T-3 wife's car
06-05-2015, 10:38 AM
This could easily be quantified with diagnostic equipment. Does the manufacturer provide any of this analysis? I'm always skeptical when a company tells you'll "feel" the difference straight away.
To me that's like a hair tonic where they just add menthol and make you believe your hair is lush and thick now since you feel the tingle.
06-06-2015, 03:50 AM
I use sea foam in my lawnmower and weed wacker. It seems to cut through the gunk from reformulated gas. I have also put it in the tank of some old British cars I have. Seems to make them run smoother after a winter in the garage. Never used it in the Boxster. Is my memory deceiving me or was there a discussion years ago about people using techron fuel injection cleaner in their boxsters and loving it?
06-06-2015, 05:36 AM
That being said, just like a humans arteries can clog up over time from the junk we eat, there is medicine that can help clear those clogs. No reason to suppose this isn't the same concept on the automotive side.
06-06-2015, 07:13 AM
There are also pills that make you lose weight
Does Seafoam Actually Work in a Car? (with Proof) - Speed Society
06-06-2015, 07:23 AM
Originally Posted by Fintro11
Yeah, and just like those pills....I've got some land down in Florida.....
Maybe a better comparison - seafoam is more like Ex-lax?
06-06-2015, 01:40 PM
X GI
I sure hope putting something in the gas tank doesn't leak into the oil...I'd really have problems. I have great results with seafoam! Seafoam is a cleaner and lubricant originally developed for Marine use. Those outboard motors get real gunked up! Put some on your fingers and see for yourself how slippery it is. But don't rub your eyes afterward. Ha ha..
Daily Drivers:
2013 Passat SE
2001 RX300
1999 Boxster
06-07-2015, 12:49 PM
I'm a little skeptical. The sea foam instructions are basically telling you to do an "Italian tune-up", go out and run the car hard to heat it up and blast the crud out of your motor. Also, the difference in carbon before and after was negligible to my eye.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
06-07-2015, 02:06 PM
Shacky
I'm a believer of Seafoam. Used it in motorcycles for years. Avoids/repares sticky valve disease, gas stabilizer in winter too.
I've heard of using it to flush crankcase too.
06-07-2015, 02:21 PM
Seafoam
This is a waste of time and money...used it on my other cars..no effect.
No way will I put it on my Boxster...no such thing as cure in a can, proper maintenance and tuneup is the only way to go!
Just my opinion and experience, then again if it satisfies your curiosity, go for it!
06-07-2015, 03:46 PM
But, what about Slick 50?
06-07-2015, 10:06 PM
cure in a can
Back in the early 80's I've used Slick50 as per advertised, looking back didn't really make any difference,especially now Synthetic oil.
It's Big Business, if people want to try them go ahead! But don't dxpect a drastic change or a perceived advantage of extra protection!
I am not an engineer, just talking from experience.. Now if Porsche recommends and back them up, then this will Totally be a new discussion and I'll leave it at that.
06-07-2015, 11:09 PM
having worked on cars on and off for 30+ years, I have found some of these additives are helpful. there are cases of carbon build up and fuel injector clogging (prior to full blockage) which will be helped by using these things. if there is a mechanical problem or no problem at all these will not help. everyone here is always changing water pumps and ims bearings, but there are no performance advantages to changing these before they fail, the car still runs the same. the same is true with these cleaners, if the engine is not dirty, they will do nothing. some like to call these products snake oil, but if you need to lubricate a snake, it might be just what you need.....
1977 Toyota Celica GT
