Old 05-29-2015, 04:16 PM   #1
Exclamation Ramps ? Enough room for Oil Change and Spark Plugs?
Got a used 1999 Porsche Boxster want to change Oil and Plugs this weekend.
I gotta tell you that I despise Jacks / Jack kits etc.
I see people on YouTube and etc. doing ramps backing 986 Boxster up to do Oil Change. Is there enough room? Is there enough room for average size guy to use ramps to do a spark plug change.
I would rather use ramps than jack any day.
Looking at some basic Rhyno Plastic ramps at AutoZone for like $45.
rvacs is offline   Reply With Quote
Old 05-29-2015, 05:00 PM   #2
Ramps will provide all the room you need to change the oil but to change the spark plugs it's easier if you remove the wheels.
2008 Boxster S PDE2
cas951 is offline   Reply With Quote
Old 05-29-2015, 05:07 PM   #3
steved0x's Avatar
Yeah, to change the spark plugs I removed the rear wheels and the front most rear wheel liner. Much easier that way. For oil changes plenty of room under the ramps.
Steve
Old 05-29-2015, 06:47 PM   #4
I did both off the ramps - No Prob - a wee bit awkward for the plugs but quite doable.
Duezzer is offline   Reply With Quote
Old 05-29-2015, 08:00 PM   #5
Multi-Boxer Driver
Deserion's Avatar
I just did a spark plug change and oil change on Thursday. Put the car on jack stands, got my fat self under there and got it done. No wheel removal, no fender liner removal. It was a little slow-going on Cyl. #4, but doable when the A/C line was pushed out of the way. Right-side of the engine is far easier.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-29-2015, 08:15 PM   #6
I did my plugs with the wheels off too. Much easier. You can just sit by the car and stick your hand in to do work. Especially when you need to wrestle with the tubes to get them out.
hancock1701 is offline   Reply With Quote
Old 05-30-2015, 01:05 AM   #7
ramps
Ramps don't allow you to drain all of the oil out, it really needs to be level.
Wild Bill is offline   Reply With Quote
Tags
boxster 986 , jack , ramps , rhyno
