Old 05-19-2015, 05:05 PM   #1
Exclamation LED tail lights
Has anyone installed the DEPO LED tail lights on their Boxster? I installed them and connected the outer ones (fog)so that they would come on with the brake lights. For some reason they only come on the second time the pedal is depressed. I have had two auto electricians look at it and they cant work it out. Doesnt seem like resistors work and the strange thing is that the lights work correctly on thebenck but as soon as they are in the car they only work by pressing the pedal twice.
gforce is offline   Reply With Quote
Old 05-19-2015, 07:33 PM   #2
BruceH's Avatar
Mine do the same. I tried the resistors also but to no avail. Take a look at this thread, same problem.
http://986forum.com/forums/diy-project-guides/56038-need-help-w-depo-led-tail-lights.html
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 05-19-2015, 10:22 PM   #3
I saw this issue so I just turned the fog location LED to my turn signals. I know that mod works
antny is offline   Reply With Quote
Old 05-24-2015, 04:37 AM   #4
Thanks - unfortunately in Australia the turn indicators have to be orange not red. What seems strange is that the lights work out of the car but when in place they don't function consistently. Are there any electronic savy people that might know why?
Old 05-24-2015, 07:57 AM   #5
Jager's Avatar
Did you connect the fog LED's in series or parallel to the brake LED's? Try changing that.
Jäger
300K Mile Club
Old 05-31-2015, 05:23 AM   #6
I would not think that makes a difference. Do you have these lights? I would think they are parallel but will check with auto electrician.
Old 05-31-2015, 06:37 AM   #7
Giller's Avatar
Really? A guy gives with over 1600 posts here gives you a good suggestion to fix a problem you can't fix -and you give him attitude? Nice.
Old 06-08-2015, 05:11 PM   #8
Attitude? Arent we being a little sensitive? If this is a theoretical suggestion then I need to find out. I would suggest you just mind your own business.
