Old 05-15-2015, 02:01 PM   #1
Pdwight's Avatar
Spring Oil Change
THis is how my Magnetic plug looked...pretty happy
Old 05-15-2015, 02:44 PM   #2
Usercpy
ilikeching's Avatar
You shouldn't be happy, that should be standard on all 986/996.
So FY Ferdinand Porsche who give us nightmares about IMS.....
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
Old 05-16-2015, 11:02 AM   #3
JayG's Avatar
if you still have the oil, send a sample to your local CAT dealer for analysis
Old 05-16-2015, 11:20 AM   #4
Pdwight's Avatar
I do ....but
The oil pan it ran into has been used for everything...one of those that traps the oil and you pour it out....no telling what is in the crevices and bottom. I need to actually find a new oil pan....this one almost runs over as the oil is draining from my Boxster
Old 05-16-2015, 11:43 AM   #5
EJ-Fresno's Avatar
Pdwight, can you please give us the part number for the magnetic drain plug?
2006 V6 Mustang
2008 ML 350
EJ-Fresno is offline   Reply With Quote
Old 05-16-2015, 11:56 AM   #7
EJ-Fresno's Avatar
Thank you sir!
2006 V6 Mustang
2008 ML 350
Old 05-16-2015, 12:17 PM   #8
Pdwight's Avatar
Cheap early warning system
Old 05-16-2015, 12:18 PM   #9
EJ-Fresno's Avatar
Yes, makes totally sense. Will order one and install at my next oil change.
2006 V6 Mustang
2008 ML 350
Old 05-16-2015, 12:21 PM   #10
husker boxster's Avatar
Isn't that a metal flake at 9 o'clock?
1989 928 S4 5 spd - black
Old 05-16-2015, 12:22 PM   #11
Ha, ha. Made you look.
Old 05-16-2015, 02:20 PM   #12
Usercpy
ilikeching's Avatar
All these will fit:
Magnetic Oil Drain Sump Plug M18 x 1 5 18mm 1 5 M18X1 5 18mm x 1 5 PSR1492 | eBay
Magnetic Oil Drain Sump Plug M18 x 1 5 18mm 1 5 M18X1 5 18mm x 1 5 PSR1491 | eBay
Magnetic Oil Drain Plug Sump Plug BMW K Series M18X1 50 K100 K1000 K1100 K1200 | eBay
Old 05-16-2015, 05:35 PM   #13
I am my own mechanic....
Timco's Avatar
And no mention of or questioning oil weight or brand?????
Just do what my dad did when I was a kid. Dig a hole and pour the oil in and it magically vanishes back into the oil reserves.
'08 VW Touareg T-3 wife's car
Old 05-16-2015, 06:59 PM   #14
JayG's Avatar
Looks like a good deal, the L&N magnetic drain plug is a lot more $. Also, I like the hex head rather than a hex key
Old 05-16-2015, 08:07 PM   #15
Pdwight's Avatar
Sorry
This is my 3rd oil change in 2 years, always Mobil 1 European formula
As for the Hex Key it is 8mm and I have never had a problem...19 foot pounds with my torque wrench and no leaks (new washer every time)
I kinda like this one
http://www.ebay.com/itm/Mishimoto-Magnetic-Oil-Drain-Plug-M18-x-1-5-Black-MMODP-1815B/151660168895?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%2 6asc%3D30987%26meid%3D93db74bcd7014e4abcd3f88498b0 7763%26pid%3D100005%26rk%3D5%26rkt%3D6%26sd%3D3505 51405102&rt=nc
BUt I like the big surface area of the one I am using
