Old 05-12-2015, 01:28 AM   #1
Oil pooling on the block behind alternator
Just thought I'd post this here as more traffic than in the DIY section but any idea why I have found oil pooling in the cast recesses in the engine block below the intake and directly behind where the alternator sits? Picture in the linked thread.
http://986forum.com/forums/diy-project-guides/24008-how-change-your-alternator.html
MogulBoy is offline   Reply With Quote
Old 05-12-2015, 02:51 AM   #2
Artist, 986S tinkerer
NewArt's Avatar
Most likely a cracked oil filler tube. This is not expensive but a bit of a pain to change.
Old 05-12-2015, 04:07 AM   #3
Thanks. I guess it has to be something high up so will see if I can find a crack or if I can just re-seat it as I moved it when I changed the expansion tank last year.
Old 05-12-2015, 07:23 AM   #4
seningen's Avatar
Check to see if oil or power steering fluid.
m
mike@lonestarrpm.com
Old 05-12-2015, 09:13 AM   #5
oil on top of engine
I also had a similar oil pooling/leaking condition in that area. I had a leak in the oil fill tube joint right at the AOS vent hose location. With advice from this great site, I switched to a screw clamp on that oil fill tube joint. I am monitoring the leak. So far, looks better.
rem503 is offline   Reply With Quote
