05-08-2015, 09:06 AM
is the oil okay
when i bought mine two weeks ago, the seller had a service, and as i can here my engine ticking on idle. remember you good folks suggesting to change oil again.
this i have not done as yet i telephoned the garage who did the service before i bought to ask what oil was put in it. they tell me its valvoline 15/40 what are your views on this oil folks could it be why the engine is ticking.or is the oil fine for engine thats done 125,000 miles.
05-08-2015, 09:28 AM
Need For Speed
Not sure about your ticking noise. I would not use that oil in your engine. This is what Jake Raby uses in all his engines.
Driven Racing Oil 02407, Driven Synthetic European Sports Car Oil | Driven Racing Oil
I've been running Mobil 1 0W-40 in my car as that's what Porsche recommends, but I may switch over to what Jake Raby uses. My car has 117k miles on it.
2003 Boxster S
05-08-2015, 09:45 AM
Did you ask them why they put Valvoline 15w40 in it? Are they brain damaged?
Yes, could be the oil, but it could also be any number of things. I'd start by putting the correct oil in.
05-08-2015, 09:59 AM
wasnt anything to do with me the guy i bought it off already had it serviced when i collected it. and when i got home 200 miles later. afew days after i was just looking through the invoice's and saw the service one and was curios as what oil they put in.
05-08-2015, 10:00 AM
15w40 is too thick. Valvoline what? They make a number of different oils. Stick with a high quality synthetic oil. DT40 is a good example of a highly recommended oil for the M96. I'd get the questionable oil out of your car and find someone that knows something about your car to do work on it.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
05-08-2015, 10:27 AM
0-40 Shell Rotella T6. 0-40 Mobile 1 - or what Jake is using.
Check out Bob the Oil Guy forum for all the oil info you will ever need, want or could digest in a lifetime.
05-08-2015, 10:29 AM
they say it was valvoline synpower 15w/40
05-08-2015, 11:46 AM
Need For Speed
Something isn't right. Valvoline does not show 15W-40 grade oil in the SynPower oil.
Valvoline.com > Products > Motor Oil > Full Synthetic Motor Oil > NextGen
2003 Boxster S
05-08-2015, 12:48 PM
98 Arctic silver 986
Definitely get that oil out of there. Motul 8100 5-40 or Joe gibbs Driven 5-40 are probably the best. At the very least Mobil 1 0-40 or Castrol syntech 0-40. Both of the latter are available at your local Walmart in 5 liter jugs. Get two. Just make sure they are the European formula with the A40 Porsche rating. Anything is better than what you have in there now.
05-08-2015, 01:16 PM
I think you want the 10-40 if you're going with the Castrol. Based on used oil analysis by a shop-owning member. I'd use it but we only have the 5-40 available in Canada (go figure), so I use that.
There are as many opinions on oil as there are on replacement IMS bearings.
05-08-2015, 01:34 PM
Originally Posted by KRAM36
wonder why they would tell me that.
05-08-2015, 01:36 PM
Yeah i hear you on the opinions. I used to use 5-40 castrol but I can't find it anymore, so I've been using 0-40. It has the Porsche A40 certification so I think i'm alright.
05-08-2015, 02:19 PM
been reading about the motul 8100 x cell 5/40 sounds like the right one to go with .
05-08-2015, 02:33 PM
I'll say that any name brand oil will work fine as long as its changed on a regular basis.
The ticking noise is likely a stuck hydraulic lifter but there are several other reasons for ticks so you'll have to do some checking to verify the cause.
05-08-2015, 05:00 PM
Just had it changed this morning.
Put in Royal Purple HPS 10w-40
Wanted the high zinc level.
But not certified by porsche.
Recommend for track cars
Out of warranty.
Jinx & Bill
