05-05-2015, 01:56 PM
#1
Coolant tank not holding vacuum
So I was proactive and replaced the coolant tank this winter along with water pump and low temp thermostat. I use the airlift today to make sure there is not air in the coolant system and it will not hold a vacuum. I can get it to 25 psi vacuum but it drops to 0 in about 10 - 15 seconds.
My guess is the new tank has a leak - yes, I know, I went with a cheapo and not factory and am probably paying the price now.
What is the downside or risk with a tank that is not airtight? Does it need to be replaced immediately or can it wait? Is it just the nuisance coolant drip on the garage floor or something more drastic?
Thanks-
05-05-2015, 02:06 PM
#2
PV=nRT
"Cool Prius!" - Nobody
05-05-2015, 08:39 PM
#3
Don't know about the risk to your engine, but if Porsche coolant is similar to regular antifreeze, the drip on the floor is toxic to pets.
05-05-2015, 09:03 PM
#4
First, check to make sure that the tank is the cause - could easily be something else.
Whatever the cause, it should be repaired as soon as you can. In the meantime, check coolant level religiously and watch that temp gauge!
If the coolant light starts to slowly blink (even if the temp is ok), it means that the coolant level is low and needs to be topped up before bad things happen.
05-06-2015, 08:38 AM
#5
if you need to drive the car and the tank is the culprit, replace immediately. Don't mess around with the cooling system on these engines, it can cost you dearly.
BORN: March 2000 - FINLAND
05-06-2015, 08:44 AM
#6
2003 S, Arctic Silver, M6
The new tank may be perfectly fine. Check all the hose connections at the tank and make sure they are secure.
I know, stating the obvious but sometimes the obvoius is missed.
05-06-2015, 11:14 AM
#7
I understand the risk is low coolant introducing an air bubble that then creates a hot spot in the head that can result in cracking.
Are you sure the Airview system is sealing well at the tank neck? I had a small learning curve to getting the guage sealed at the neck. If so - put it under pressure and then check for leaks.
05-06-2015, 11:20 AM
#8
Put some UV dye in the coolant and pressurise the system. You should readily see where the coolant is leaking.
If you don't see an external leak, take out the spark plugs and and pressirise the system, then put a piece of hose in each spark plug hole and listen for a hiss. If you hear a hiss, my condolences, you have a serious problem with a cracked head.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
05-06-2015, 12:04 PM
#9
2 fast 4 U
I would check the o rings in the pressure release valve especially with the cheapo tanks they seem to always leak. I had the same problem on two after market tanks.
Drive it the way it's meant to be driven!
2000 Boxster S
05-06-2015, 12:13 PM
#10
I checked the o rings in the pressure relief valve and the larger ring was bad - replaced it and the relief valve holds better than before but still leaks.
I can now trace the leak to the point where the pressure relief valve mates to the tank - you can hear the hissing after using the Airlift and creating a vacuum.
Unfortunately, since it is still not airtight, the coolant expands when hot and overflows. I have ordered a genuine Porsche OEM tank and learned a lesson to not cheap out on that part!
Whay a pain!
05-06-2015, 03:35 PM
#11
If you are sure its the bleed valve, I would try goobering the mating surfaces with something, silicone or JB weld to see if it will hold presuure. A lot easier than changing out the tank!
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
05-07-2015, 07:33 AM
#12
Whay a pain!
You are not the first and certainly will not be the last person to learn that particular lesson the hard way!
'99 black 986
05-12-2015, 01:28 PM
#13
Do not buy cheap tanks!!!
I replaced the el cheapo tank with a genuine Porsche tank from Pelican and guess what - it now holds a vacuum. I admit I vacuum tested the new tank before installing it and it was good.
The bad tank had aflaw in it by the overflow relief that kept it from ever sealing, the injection molded plastic did not travel to the far ends of the mold.
Lesson learned!
