Old 02-15-2015, 11:48 AM   #1
BIGJake111's Avatar
Boxster 6 speed stuck in 5th gear
Title speaks for itself, was driving the car, tried to leave 5th for 4th grinded, car will not Leave 5th gear.
Old 02-15-2015, 11:53 AM   #2
BYprodriver's Avatar
Check shift cable connection at trans 1st. If still good then you have to remove console to check connection at shifter.
Old 02-15-2015, 12:03 PM   #3
BIGJake111's Avatar
Got the car out of gear with my father down in the linkage, he said a sleeve had fallen. Got it done in an ingles parking lot.
Old 02-15-2015, 12:13 PM   #4
BIGJake111's Avatar
Driving easy, got it to a qt for a fill up, the purpose of the trip, about to nurse it home.
Old 02-15-2015, 01:18 PM   #5
I am my own mechanic....
Timco's Avatar
Shift cables fell or popped off.
'08 VW Touareg T-3 wife's car
Old 02-15-2015, 01:38 PM   #6
BIGJake111's Avatar
Home now, reverse through 6th are fine. Guess it's good. Worked out of 5th with my father working on the linkage once out it all feels good now. Just gonna baby it a bit.
Old 02-15-2015, 05:50 PM   #7
Glad it worked out for you. Did you determine with certainty what the issue was. You would not want it happening far from home.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 02-15-2015, 06:40 PM   #8
Timco's Avatar
Originally Posted by amitmishra4 View Post
Glad it worked out for you. Did you determine with certainty what the issue was. You would not want it happening far from DAD.
Fixed that for you......
Old 02-15-2015, 06:53 PM   #9
Fintro11's Avatar
lol timco !
Fintro11 is online now   Reply With Quote
Old 02-15-2015, 07:02 PM   #10
BIGJake111's Avatar
Lol not gonna lie, it was a good time to have someone in the car with me. Took two people regardless though. Everything feels good, gears just got stacked and took some working loose.
Old 02-15-2015, 07:36 PM   #11
Jake. Quit breaking Boxsters
Old 02-15-2015, 08:42 PM   #12
BIGJake111's Avatar
Argh I am trying haha. I have a Bosch maf sensor coming in the mail, everything should be solid then!
Old 02-16-2015, 07:51 AM   #13
Multi-Boxer Driver
Deserion's Avatar
Had that happen to me in my dad's 964. In that case, though, it was stuck in 4th and the plastic bushings in the shift rods finally disintegrated and the rod fell off. That was fun starting from stops.
New inserts in the cups, bam. Shifts like butter.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 02-16-2015, 07:19 PM   #14
Wait! BigJake had a posting asking for help??? I'm impressed.
Old 02-16-2015, 07:41 PM   #15
Retroman1969's Avatar
I once had a manual shift car that would hang up hard in gear from time to time. Turns out the main bushing at the base of the shifter was worn out. Replacing the shifter mechanism fixed the problem.
