Old 02-12-2015, 08:15 PM   #1
Pdwight's Avatar
Exhaust bolt replacement ...Stainless or ?
I have one of my secondary cat bypass pipes off right now, the bolts while still quite functional are ugly from the heat of 15 years and 70K miles....I have a great supplier locally who has everything from Stainless to Grade 8 and up in bolts. What would you guys use to replace yours ? and if stainless would you use anti seize to help the next time they are removed ??
Thanks in advance
Dwight
Old 02-13-2015, 05:45 AM   #2
Thanks in advance
Dwight
Yes, and yes.
Old 02-13-2015, 10:17 AM   #3
Pdwight's Avatar
Wow M8 x 1.25 carriage bolts are hard to come by
Old 02-13-2015, 01:30 PM   #4
Xpit77's Avatar
Use stainless everything.Bolt nut washers and lock washers.
Grade 8 is the wrong application.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
Old 02-13-2015, 04:00 PM   #5
Pdwight's Avatar
I am
I already sourced them at Mr. Metric , I know Grade 8 is carbon
Old 01-26-2017, 02:05 PM   #6
WillH's Avatar
So you're saying I'm not likely to find them at Home Depot tomorrow after work. I was hoping to have these pipes buttoned up tomorrow night
Old 01-26-2017, 03:44 PM   #7
Carriage bolt ? Don't you mean hex head ? Carriage bolt is for wood .
Old 01-26-2017, 03:58 PM   #8
Pdwight's Avatar
carriage bolts
Part of the exhaust hardware are some bolts that look like carriage bolts. Pan head with no slots and a shallow self locking square just above the threads and below the head.
Old 01-26-2017, 04:04 PM   #9
WillH's Avatar
Nope, carriage bolts are used in the exhaust clamps for the secondary cats/by-pass pipes to U-pipe connection. Metric carriage bolts...
Might be replaced with regular stainless bolts tomorrow afternoon...
Edit
Pdwight got it in first...
Old 01-26-2017, 04:19 PM   #10
Metric carriage bolts are available in stainless steel, even Amazon sells them.
Old 01-26-2017, 05:52 PM   #11
Project Addicted
jcslocum's Avatar
Regular SS hardware for home dope or local hardware will work just fine.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
Old 01-26-2017, 09:12 PM   #12
Pdwight's Avatar
Yes it would
Actually anything that would pull the clamps in would be OK......that being said Mr Metric is a wonderful resource for hard to find fasteners (I have no involvement whatsoever with them)
Old 01-27-2017, 02:06 PM   #13
WillH's Avatar
So no love at mr metric. McMaster Carr same. Fastenal has them but want 50 some odd bucks cdn. for a box of ten.
I'll be using regular bright bolts and not worrying about it. They will probably only be on for a year or so before the muffler gets changed out for a magnaflow and the the u-pipes go into the garage attic with the rest of the stock stuff.
Old 01-27-2017, 08:00 PM   #14
Pdwight's Avatar
Try Here
m8-1.25 STAINLESS STEEL METRIC CARRIAGE BOLT
Old 01-27-2017, 08:40 PM   #15
Stainless studs for the headers may also be of interest?
Old 01-27-2017, 09:48 PM   #16
Pdwight's Avatar
Size
Do you know off the top of your head (what a funny way to put that) what size they are ?
Old 01-28-2017, 09:49 AM   #17
It may be easier to 'cheat' and use a 5/16" bolt.Choose your length carefully.Nordlock washers also?
https://www.boltdepot.com/Carriage_bolts_Stainless_steel_18-8_5_16-18.aspx
http://www.ebay.com/itm/Stainless-Steel-Carriage-Bolt-25-5-16-18-x-1-1-2-/201736255999?hash=item2ef86af9ff:g:6nIAAOSw-0xYQZ2H
