Old 01-30-2015, 08:49 AM   #1
Camshaft deviation
I recently purchased a 2000 S with 102K miles , 1 owner full service records, recent clutch, rms, IMS bearing and many other new parts. I had a independent Porsche shop go through the car with only 1 comment regarding camshaft deviation, 5.4 and 8.2 readings. After placing and reading several postings on the subject I had decided to have the chain ramps and guides replaced before putting it on the road this spring. This past week I had a lengthy discussion with a recently retired Porsche technician . He was a graduate of the academy, with 35 years experience at the only Porsche dealership here in Maine. For many of those years he was the head technician at the dealership. His response to my situation was to drive the car with enthusiasm as it was designed to be driven. He said that the computer controls were very sensitive to any situation that was out of specification and I would have ample warning if anything had potential for trouble. He commented that he did not regularly check camshaft deviation unless he had a drivability issue or check engine light to give him reason to do so. He went on to say that without previous readings I would have no idea if this was recent change or could have been this way for many years. I had already called the independent Porsche shop that had serviced the car for many years and they had never checked for camshaft deviation either.
I am now wondering if the whole issue of camshaft deviation has been blown out of proportion and in fact many unsuspecting owners are driving around with camshaft deviation numbers beyond limits and no problems.
My car idles smoothly with no noise on cold start , and no check engine light.
Any thoughts , comments , etc regarding the above?
Ptriggiani is offline   Reply With Quote
Old 01-30-2015, 08:54 AM   #2
steved0x's Avatar
I am interested as well; I am at -6 on one side and -5.8something on the other side but it hasn't moved (from what I can tell, I did check them with durametric but I didn't write them down) in the last 3 years/15000 miles.
Old 01-30-2015, 08:54 AM   #3
Reebuck1
Ask Jake Raby ! He will know the answer to that question better than almost anyone else>
Reebuck1 is offline   Reply With Quote
Old 01-30-2015, 08:57 AM   #4
recycledsixtie
recycledsixtie's Avatar
Pt I am just about to send you a pm...
Guy
Old 01-30-2015, 09:30 AM   #5
The system limits are +/- 6 degrees; measurements should only be taken the engine is fully warmed up, like after a drive, otherwise the results would be meaningless.
Cam deviation values are useful for two purposes: First, if they are swinging back and forth wildly at idle, something in the can drive (read IMS) is coming loose and caution is necessary. Second, if the values are steady but outside the limits, it is sign of chain tensioner wear pads wearing out and needing to be serviced. In either case, the car will run fine and not code, but both require steps to correct before problems set in.
Old 01-31-2015, 06:46 AM   #6
pjq
European Auto Surgeons in Gardiner, they have attended one of Jakes courses, they have worked on my car, they have a PST2 diagnostic tester and I wouldn't hesitate trusting them with my car. I don't feel the same about the nearby dealer.
What was your independent shop's comment on the cam deviation?
Old 01-31-2015, 01:54 PM   #7
I took it to Autowerks in Freeport they used to be in Gardner. They have serviced my BMW's for years and I have always trusted them. Every time I go there he has 2-3 P cars on the lift. Voit is the owner and his take on it was to drive it and check the deviation regularly. When and if it changes, then take action. When they changed the oil (7-8K miles on it) there was no evidence
of any plastic or metal in the filter(spread out and examined with magnifier and magnet). He had me watch as he examined it.
