Old 11-19-2014, 06:55 PM   #1
Pdwight's Avatar
A question for those who have replaced the water pump
I have a good sized job coming up, new trailing arms, new parking brake shoes, rebuild or re lube and install new boots on the CV joints and new wheel bearings on the rear.....also in that lineup is a new Motor Mount...I have everything sitting in my garage and I was pondering the question. Is it a lot easier to replace the water pump once you have the motor mount off ?
My water pump is not giving me any problems, no noise, no leaks nada....but my Bavarian Beauty just turned over 70 K miles and well...should I or wait for problems ??
Dwight
Old 11-19-2014, 07:06 PM   #2
ChrisZang's Avatar
Dwight
It makes no difference if the motor mount is on or off
You write "my Bavarian Beauty" did you accidentally buy a BMW and think it's a Porsche? Porsches are not from Bavaria. Hint: if the engine is up front it's actually a BMW ;-)
Old 11-19-2014, 08:03 PM   #3
Pdwight's Avatar
Yes a Typo
I do have a E36 with 147K on the Odo and it is one of the best cars ....if not the best car I have ever owned
PS I appreciate the info on the water pump.
Old 11-19-2014, 08:51 PM   #4
I am my own mechanic....
Timco's Avatar
'08 VW Touareg T-3 wife's car
Old 11-20-2014, 03:36 AM   #5
Artist, 986S tinkerer
NewArt's Avatar
Wow. Don't think I'd be using the Cos as my surrogate to post a comment right now...
Old 11-20-2014, 03:50 AM   #6
Timco's Avatar
The Cos didn't drive Ms. Daisy.......
Old 11-20-2014, 04:40 AM   #7
NewArt's Avatar
Haha. Shoot me, I'm stupid. You're right of course!
Old 11-20-2014, 04:45 AM   #8
mikesz's Avatar
I replaced my water pump, thermostat, and front motor mount. check out Pedro's diy. Once you take out the motor mount the water pump is a breeze. I removed the engine cover inside the car and got it up on jackstands to get underneath.
99 Porsche Boxster
Old 11-20-2014, 04:47 AM   #9
mikesz's Avatar
Keep us posted on your suspension refresh. I am planning on doing same with my 99 DIY. But may hold off due to co$t!
99 Porsche Boxster
Old 11-20-2014, 08:48 AM   #10
bwillia080261's Avatar
That would be a Swabian beauty!
bwillia080261 is offline   Reply With Quote
Old 11-20-2014, 09:31 AM   #11
It is much easier to replace the WP with the motor mount removed. You can get a torque wrench on every WP fastener.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-20-2014, 09:44 AM   #12
Giller's Avatar
RIP Morgan Freeman?
Old 11-20-2014, 09:54 AM   #13
Timco's Avatar
Originally Posted by Giller View Post
RIP Morgan Freeman?
Old 11-20-2014, 10:47 AM   #14
Nice baiting in the thread Timco.
I understand that taking the water hoses off to drain the coolant makes it easier to drop the front engine mount during removal of the mount. Being able to torque all of the water pump bolts is something I did not know could be accomplished with the motor mount out of the way.
Old 11-20-2014, 10:51 AM   #15
Timco's Avatar
Just stuff I find online. There's great ones.
Old 11-20-2014, 12:22 PM   #16
still plays with cars...
BoxsterSteve's Avatar
Torque wrench is nice, but not necessary. I just snugged the water pump bolts up, and gave them another quarter turn.
The vacuum fill tool held 25" of vacuum for a half hour, so I surmised I was leak free.
Six speed 2000 Boxster S
Old 11-20-2014, 04:47 PM   #17
I'd hold off on the pump as you have no symptoms and your upcoming tasks are not related to the WP so there is no "while I'm there" cost or time savings.
and I just replaced my WP at 119K miles due to a small drip. After getting to the pump, I just saw a small drip from a lower bolt. Since I was in that far and had the part on hand, I went ahead and replaced the WP and thermostat. After removing and inspecting the (original) pump, I noted no bearing play or wear to the pump veins
Given small torque spec for the WP (12-14 Ft-lbs) I'm fairly certain that I could have re-torqued the bolts a and been good to go. Looking back, I should have tried it.
I even kept the old pump!
Old 11-20-2014, 05:16 PM   #18
Pdwight's Avatar
Thanks Folks
Old 11-20-2014, 09:07 PM   #19
Jager's Avatar
I found that a 10mm deep well socket with 1/4" drive will be your friend when replacing the water pump.
Jäger
300K Mile Club
Old 11-21-2014, 10:43 AM   #20
CoBeerToad's Avatar
I did both a few months ago. I don't think it would have made that much difference.
CoBeerToad is offline   Reply With Quote
