Old 03-21-2006, 06:39 PM   #1
headlight lens
the '97 boxster that i am considering to purchase have headlights that have turned yellowish. can the lenses be changed or does it have to be the whole assembly? if lenses can be changed, where can I get these lenses?
jr1966 is offline   Reply With Quote
Old 03-22-2006, 05:58 AM   #2
You can clean the lenses pretty easily. There are some products on the net for cleaning plastic head lights.
Other methods include wetsanding the lense with 1200 grit wet sandpaper using WD-40 for the "wet" as a lubricant. This will bring them right back to their original luster.
http://www.autogeek.net/plastik-lens-cleaner.html
http://www.superiorcarcare.net/plastik-lens-cleaning.html
http://www.autopia-carcare.com/meg-g-12310.html
Regards,
986Jim is offline   Reply With Quote
Old 03-22-2006, 06:00 AM   #3
Hi,
The Headlights and lenses are an integral unit. As mentioned, you can reclaim them, but lots of elbow grease...
Happy Motoring!... Jim'99
Old 04-18-2006, 01:52 PM   #4
Can they be replaced? If so, is the parts dept the only source for these?
Both of my lenses have nickel size spots that appear yellowed and melted.
kabel is offline   Reply With Quote
Old 04-18-2006, 02:19 PM   #5
Perfectlap's Avatar
Try Plexus and Renovo. That should remove the yellowing but burns are not comning out.
BORN: March 2000 - FINLAND
Old 04-18-2006, 02:55 PM   #6
Entire assembly needs to be changed....unless you can clean them with one of the methods listed...
docdyh is offline   Reply With Quote
Old 04-18-2006, 04:41 PM   #7
buy used ones off ebay... stealerships want $$$$
... even for amber halogen versions.
Old 04-19-2006, 08:30 AM   #8
Ironic you would use the word 'stealership' in this post, as the used litronics on ebay are most often stolen items, sold through a number of hands so the person selling on ebay has no connection with the actual theft - directly, anyway...
Todd
2005 Boxster S - Atlas Grey/Black, PASM, Sport Chrono, Bose
2006 Infiniti M35 Sport
2007 Cadillac Escalade (tow vehicle with bling)
'00 Boxster - 2.7l w/FVD ECU tuning, Moton double adjustable suspension, custom stainless headers, lightweight flywheel, dual Magnaflow mufflers, 18" CCR wheels, 911 front brakes in front, Boxster front brakes in rear, full welded cage.
http://www.epiqautosport.com/images/epiqtoddavatar2.jpg
EPIQTodd is offline   Reply With Quote
