View Poll Results: Does your Boxster Rattle ?
It does not rattle at all 35 36.08%
It gores away very quickly 56 57.73%
It rattles until it get to 180 deg. (or normal temp) 3 3.09%
It always rattles 3 3.09%
Voters: 97. You may not vote on this poll
Old 10-26-2014, 07:56 PM   #1
Pdwight's Avatar
Does your Boxster rattle on startup ?
and how long does it do this ?
Old 10-26-2014, 08:18 PM   #2
Porsche9's Avatar
What rattles?
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 10-27-2014, 12:16 AM   #3
Steve Tinker's Avatar
The timing chains can rattle before the tensioners pump up.
Mine does, for about a second after the engine fires.....
2001 MV Agusta F4.
Old 10-27-2014, 03:37 AM   #4
BIGJake111's Avatar
Listening out this morning after seeing another thread on the topic, I had a small rattle for a second or two then gone.
Old 10-27-2014, 04:07 AM   #5
kk2002s's Avatar
Not 100% of cold start ups
Mostly after it sits for many days
Seal Grey
Old 10-27-2014, 04:27 AM   #6
jsceash's Avatar
Neither my cars original engine 2.7 2003 (42K) or the rebuilt 3.6 (21K) make any noise when starting.
Old 10-27-2014, 05:24 AM   #7
Retroman1969's Avatar
Mine has just recently started doing this, but only for a second after cold startup, and usually only after sitting several days.
Old 10-27-2014, 05:54 AM   #8
steved0x's Avatar
I did used to have some rattle but I think it was from the exhaust, like a heat shield or something, now that I replaced the 2nd cats with test pipes it has gone away.
Steve
Old 10-27-2014, 10:38 AM   #9
mine rattles for a second or so after startup, more if it sits for several days, the rattling stops at the same moment the oil pressure light goes out. There is an o-ring between the oil pickup tube and the pump suction and I plan to replace that to see if things improve. I am thinking to replace the spring and plunger in the oil pump relief valve to see if that improves things, 2nd step is going to be an oil pump replacement. I will post the results of these efforts as I plan to do them one by one
oldboxster is offline   Reply With Quote
Old 10-27-2014, 03:50 PM   #10
lkchris's Avatar
Sounds like lifters or cam chain to me, but my mechanic says that rattle--only when really cold and not run for a few days--can be IMS bearing.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 10-27-2014, 03:56 PM   #11
jacabean's Avatar
chain rattle , my 03 s does it after it has been sitting for awhile . my 996 3.4 does it more often.
Old 10-28-2014, 03:07 AM   #12
Mine rattles on start up and gets better as it warms up...also rattles at lower rpms when accelerating between 1000-2400 range. Was told it might be one of my cats because the sound seems to be coming from the exhaust. Getting a full diagnosis later this week.
Einherjar is offline   Reply With Quote
Old 10-28-2014, 03:50 AM   #13
Heiko's Avatar
Mine doesn't rattle when its cold or when its hot... It used to rattle for about 3-4 seconds on cold starts before I changed the cam chain guides, tensioners and variocam pads; But I haven't heard it since the rebuild
Previously owned:
Old 10-28-2014, 09:02 AM   #14
No rattles here, even if the car sits for a week which it usually does. I'd be worried about any rattles.
Steve
BerneseMtnDog is offline   Reply With Quote
Old 10-28-2014, 09:14 AM   #15
No rattles during start up. But, I think I hear one when I am at really low speed and low gear.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 10-28-2014, 09:49 AM   #16
Mine has the less than one second rattle on startup when cold and hot if its been sitting for a couple of hours.
Sounds like your rattle is from lugging the engine. Do you hear it when you accelerate or at an even throttle. If its under acceleration then you're lugging the motor, not good.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-01-2014, 09:54 AM   #17
DennisAN's Avatar
When I first got my 986 it rattled for a second at startup. But during the IMS bearing install I pumped up the two removed chain tensioners in a pot of fresh oil before replacing them. After that no rattle at startup. It may be the two tensioners were "gummed up" somewhat since the car had barely been driven in the two years before I bought the car this past February. The dealer changed the oil before my purchase so this was also the second oil change in maybe 2K miles.
I suppose I could do the same for the Bank 2 chain tensioner too. But it faces downward so it's likely to drain between uses...so maybe it's less likely to get gummed up from used oil siting in it.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
Old 11-01-2014, 02:46 PM   #18
found my problem. It is a loose heat shield on my rear right cat.
Old 08-03-2017, 02:43 PM   #19
is this about the sound you hear with the startup?
only does it on the very first cold start, can turn the car off and on and it wont do it.
Is this the lifters?
https://youtu.be/OhXTLetpVVc
Lucassharringtonn is offline   Reply With Quote
Old 08-05-2017, 07:44 PM   #20
redciv1's Avatar
Mine's rattles at startup for a second 1st start of the day or after car sits for several hours. Read somewhere that the flat six tends to do this after so many miles. My car has 137k with IMS done
redciv1 is offline   Reply With Quote
