Old 07-04-2014, 09:43 AM   #1
Miata2Boxster's Avatar
Does your 986 smoke i the morning.
Every morning when I start my 2001 base it spews out smoke .....looks like the bat mobile in hot pursuit for a few moments....then it is fine the rest of the day. Is this characteristic of 986 Boxsters?
thanks
2001 Forest Green Metallic Boxster with Porsche Sport Exhaust.
Miata2Boxster is offline   Reply With Quote
Old 07-04-2014, 09:58 AM   #2
No, not normal.
That is more characteristic of a Boxster whose air-oil separator is preparing to fail.
Old 07-04-2014, 09:59 AM   #3
Mine does not. It's a 2000 base.
Rick
SoCalBlackbox is offline   Reply With Quote
Old 07-04-2014, 10:26 AM   #4
Perhaps I have a slow gas drip from my fuel injectors. It accumulates in the morning, is burned off then is fine during stops and starts the remainder of the day.
Old 07-04-2014, 10:43 AM   #5
No and your last post describes a failing AOS.
Old 07-04-2014, 11:16 AM   #6
OK, interesting, makes more sense..I'll check into it. thanks
Old 07-04-2014, 11:28 AM   #7
RawleyD's Avatar
Sounds more like you are not bringing the car up to running temp before you park it. Have you been?
:ah:
Old 07-04-2014, 12:08 PM   #8
Sometimes, I'll see if that makes a difference. Thanks!
Old 07-04-2014, 06:37 PM   #9
Tucker2's Avatar
If it's had morning sex, then yes, she smokes.
I digress. Apologies.
Serious note: Yes...clear sign of AOS. Try this....while running, take the oil fill cap off and place your hand over the opening. If there is a very strong pull, that is another sign of a failing AOS. A working AOS should have a very mild/gentle pull.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 07-04-2014, 06:52 PM   #10
Thanks! Will do!
Old 07-04-2014, 08:05 PM   #11
i thought this WAS NORMAL. there are other post regarding this as well. mine blows a puff of white smoke. on other posts, many others experience it too and we just all assumed it was normal. no cel.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 07-04-2014, 08:06 PM   #12
Fintro11's Avatar
every now and again it will do it but not very often
Old 07-05-2014, 07:40 PM   #13
I am my own mechanic....
Timco's Avatar
This. On a damp or cool morning maybe white smoke. After an oil change if a bit high and some spirited driving, a bit o smoke. New AOS helped.
'08 VW Touareg T-3 wife's car
Old 07-05-2014, 09:53 PM   #14
BIGJake111's Avatar
My old boxster did, and it had a new AOS also, my new car does not though? So ummm yeah it is odd, but i do not think it is AOS as the old car had the AOS done within the last 4k miles.
Old 07-06-2014, 04:27 AM   #15
WALDMEISTER
BRAN's Avatar
A few seconds white smoke on start up = the so called "Boxster fart" (nothing to worry about, if it only happens occasionally)
Gute Fahrt!
Old 07-06-2014, 07:56 AM   #16
steved0x's Avatar
If I drive mine only a very short distance, like into the driveway to wash it and then back to the garage I may get a little puff on startup. Otherwise I get none.
Old 07-06-2014, 10:44 AM   #17
Mine has done it a couple of times when it wasn't sitting on level ground.
Old 07-06-2014, 10:09 PM   #18
jacabean's Avatar
I find if I let the car idle for a minute or two after a spirited ride , I don't get smoke the next day and I also have a new AOS .
Old 07-06-2014, 10:37 PM   #19
Pdwight's Avatar
No
I have had my Boxster 14 months and it has smoked 3 or 4 times in that entire time. As a rule it never smokes on startup. I hate the way they sound on startup however...like a worn out 70's era motorcycle...but every Porsche I have ever heard sounds that way.
