Old 06-28-2014, 05:36 PM   #1
Oil leak on top of engine, by oil cooler
I was changing out my 2002 986 starter today, and discovered oil on top the engine by the oil cooler. Has anyone experienced this issue before?
I am trying to figure out where the leak could have originated from but not having any luck.
boxstergeek is offline   Reply With Quote
Old 06-28-2014, 06:29 PM   #2
Tucker2's Avatar
I had multiple oil leaks from my spark plug tubes. It's tough to figure out where the oil is coming from due to the airflow. Check the tubes.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 06-28-2014, 06:30 PM   #3
The Radium King's Avatar
oil or power steering fluid?
Old 06-28-2014, 07:01 PM   #4
Beginner
Jamesp's Avatar
Look forward of the oil cooler. I had an AOS that was putting oil into the manifold and it was mainly draining out of the balance tube butterfly valve and landing on the left front / left center of the engine.
2003 S manual
Old 06-29-2014, 07:35 AM   #5
The oil cooler seals to the engine case by four O-rings, you may have lost one of them.
Old 06-29-2014, 12:14 PM   #6
I checked the fluid, it is motor oil. At first I thought it was pentosin, but after using paper towel to absorb it... it was definitely motor oil.
Old 06-29-2014, 12:20 PM   #7
Tags
oil leak
