Old 06-20-2014, 03:25 PM   #1
2000 Boxster won't start
My 2000 Boxster won't start. When I turn the ignition, it's like the clutch isn't pushed down far enough. But it's all the way down and the battery has full power.
trobertson is offline   Reply With Quote
Old 06-20-2014, 06:26 PM   #2
Does starter spin? If so, its not the clutch switch. If the starter doesn't spin, you can easily bypass the clutch switch and see if it starts.
Do gauges work? Lights?
More info is needed to help you out!
Old 06-21-2014, 04:57 AM   #3
yes all gauges work it locks the starter doesn't spin. it's like the battery is dead. how do I bypass the clutch?
Old 06-21-2014, 09:57 AM   #4
I am my own mechanic....
Timco's Avatar
Look at the top of the clutch arm. There's a plunger type switch that gets pushed in as the clutch is pressed in. In most Boxsters you can hear the click of it being pushed in and releasing. Take those wires off, make a jumper.
'08 VW Touareg T-3 wife's car
