Old 06-11-2014, 10:33 PM   #1
Hawaiian Driver
Hawaiian Driver's Avatar
Red Brake Calipers
Any suggestions on keeping them beautiful? Mine are in great shape and I'd like to keep them that way, Thanks
2005 Boxster S 6 Speed
Hawaiian Driver is offline   Reply With Quote
Old 06-11-2014, 11:54 PM   #2
Pdwight's Avatar
Tag , mine have the coating worn off :-(
Old 06-12-2014, 01:36 AM   #3
Steve Tinker's Avatar
1) Never remove a wheel without using the screw in alloy wheel location tool found in the toolkit. Better still, get a second location tool to prevent the wheel tilting & scoring the calipers.
2) You need to remove the wheels to clean the calipers inner and outer (especially the inner surface) the first time you clean them. Once clean, normal shampoo works well.
3) Use a good quality brake cleaner - don't use el-cheapo high acidic cleaners as they will attack the caliper's clear coat & make them go dull.
4) Use a good polish to help repel brake dust - I use a spray on detailer after washing the car for great results.
2001 MV Agusta F4.
Old 06-12-2014, 02:06 AM   #4
Pdwight's Avatar
Recoat
Mine are dull, that way when I got the car. Is there any easy way to re-coat them ??
Old 06-12-2014, 06:11 AM   #5
kk2002s's Avatar
I refinished just the clear coat as it was pealing off.
I scraped the pealing sections with a plastic scrapper, then cleaned with soap and water. Used an abrasive foam block (Home depot) then washed again.
Then I sprayed a High temp clear coat from Auto parts store and I was very happy with the job. It's been a year and no pealing
I also painted the rotor hats as well to eliminate rust. That was high temp color paint
Did over a couple days to get several coats on with good dry time
Seal Grey
Old 06-12-2014, 06:25 AM   #6
I agree with the prior comments. With the wheel off, I carefully clean with brake clean and then coat the caliper with RejeX polymer, which repels brake dust. I also painted the rotor hats with a high temp Titanium spray paint, which really cleans up the whole look. Good luck!
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 06-12-2014, 06:57 AM   #7
Give me a name of a good brake dust remover - I used Meguiar's Hot Wheels and now all 4 clear coats are peeling.....
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
peterbrown77 is offline   Reply With Quote
Old 06-12-2014, 03:23 PM   #8
M31
M31's Avatar
Mine were also dull when I got the car. I've tried many products that did a good job of cleaning them but in the end still left them dull. Just for the heck of it I tried something that I use on my black BBQ lid that makes it shine like you wouldn't believe so I tried olive oil applied with paper towel and the red callipers shine like they just left the factory! The rear wheels are easy but the front ones have a much tighter working area so I do one part of them and move the car about 2-3 inches before doing the rest. Only down side is I have to wash hands before moving the car since they get all messy with the olive oil.
M31 is offline   Reply With Quote
Old 06-12-2014, 06:32 PM   #9
Tucker2's Avatar
Really? How long does it last? That sounds like one of those too-good-to-be-true things.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 06-15-2014, 08:36 PM   #10
M31
M31's Avatar
I know it sounds too good to be true but I swear it works! Just a light coat is all you need and I find it lasts 2-3 weeks or until the next washing... then just re-apply some more.
