Old 06-03-2014, 08:43 PM   #1
Ckrikos's Avatar
Anyone here ever flush their coolant?
I just purchased some aftermarket all aluminum radiators for my TT via a group buy (because I noticed some light weeping on my center and driver side radiators while cleaning them) and am considering installing them myself. I am considering getting the uview 55000 vacuum to refill the system. I typically would take my car to an indie, but no matter which one I go to I always get the feeling my car has been abused in some way after picking it up. I felt that way with my boxster and don't want to really subject the TT to it.
Has anyone ever done this how difficult is it to do? Both radiators and flushing? I realize they are different cars, but they aren't that different.
radiators
LB/GG/MB 02 2.7 sold
MB/GG 02 996TT
Old 06-03-2014, 10:07 PM   #2
BruceH's Avatar
I actually am close to purchasing this system to do my 986 and my Tundra. Both could use new coolant and from what I have read, it should be within my capabilities Amazon has it for a pretty good price, I just have too many other things to do right now before I can get to it.
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 06-08-2014, 12:34 AM   #3
nieuwhzn's Avatar
I think the uview 55000 works on shop air? Venturi vacuum system?
Does anyone knows if you can just buy the system without the venturi? I have access to vacuum pumps so I don't need to use shop air to draw a vacuum.
nieuwhzn is offline   Reply With Quote
Old 06-08-2014, 06:28 AM   #4
Ckrikos's Avatar
I thought it worked with a basic compressor.
Sent from my LG-LS980 using Tapatalk
MB/GG 02 996TT
Old 06-08-2014, 06:38 AM   #5
kjc2050's Avatar
Yes, it works on shop air/an air compressor. I've never seen the system for sale w/o the venturi.
Old 06-08-2014, 02:52 PM   #6
steved0x's Avatar
Ecstuning now has their version of it for sale for a little cheaper. I have the uview and used it to flush the coolant on my Tacoma. The hardest part was draining all the old coolant. I was never sure so I ran the truck until the thermostat opened, and then drained the radiator while I poured in a continuous flow of distilled water, until it came out mostly clear. Then I used the uview to refill it. No air and no problems since.
Old 06-08-2014, 04:05 PM   #7
Moderator
Sort of- yes. When my radiator cracked I drained all the coolant, replaced the radiator and then refilled with new coolant. Bled the coolant manually, no qualms. I think Bruce told me a link to an air purge system that requires an air compressor which gets rid of air locks.
Old 06-08-2014, 08:47 PM   #8
I drained mine when I installed the LN low temp t-stat. Refilled with factory coolant and drove for three days with the purge valve open, topping when necessary. When coolant level stabilized, shut valve and was done. No issues...:dance:
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 06-08-2014, 09:30 PM   #9
Anyone ever flush their coolant?
Isn't that a euphemism for having sex? Well if it wasn't before, it should be one now
