Old 02-27-2006, 12:52 PM   #1
fab
fab's Avatar
clay bar
I was wondering where should I purchase and what kind of clay bar should I use on my car? I've never done this before and any suggestions/tips/feedback is greatly appreciated.
Fab
00 Boxster Blk/Blk tip
fab is offline   Reply With Quote
Old 02-27-2006, 01:22 PM   #2
Perfectlap's Avatar
Over the counter Pepboys and those auto shops have Clay Magic and Mother's and Meguiar's. Not cheap they force you go buy a whole bottle of quick detailer to use as lubricant.
Go to autopia-carecare.com for how to and to buy their Sonus brand of clay.
Zaino also sells a good clay without having to buy the quick detailer.
Old 02-27-2006, 06:20 PM   #3
I used Meguiars clay system cost 15.00 last weekend on the porsche did a really nice job and very easy to use pulled alot of crap out of the paint. This past weekend I used it on the Camaro WOW what a difference. Just Remember don't drop it... O got it from autozone
Used the Meguiars NXT and the MicroFiber Towel as recommended on a thread here and was really happy with that out come too..
:dance:
Badboy S
2000 Porsche Box S arctic silver
2007 Sierra Crew Cab Z71
1995 Honda Civic *Track Toy*
1971 Olds Cutlass Convertible
1968 Camaro SS 396 4 speed
2000 V Star 1100
BadBoyS is offline   Reply With Quote
Old 02-27-2006, 07:46 PM   #4
Fab
Even pressure, not too hard and LOTS of lubricant (soapy water works great or water with a little Glycerin). Start at the Top and work your way down to avoid picking up anything which may scratch.
I tear the Clay into two pieces. I use one piece for the Top half of the Car, say to the Cut Line or Mid-Door, and the other for the Bottom parts, safe over sorry approach...
Happy Motoring!... Jim'99
Old 02-27-2006, 10:31 PM   #5
If you DROP the clay bar, the 2 second rule DOES NOT APPLY! Throw away the bar, don't take any chances.
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
Old 02-28-2006, 05:52 AM   #6
Go with Zaino. I use it on my Mercedes and Lexus and it works great! There is a general consensus that it is one of the best and there are directions enclosed when you order it.
______________________
2005 Porsche Boxster
2007 Lexus LS460
2004 Lexus RX
luxury1 is offline   Reply With Quote
Old 02-28-2006, 06:59 AM   #7
I don't know if there are big differences between the brands, but MNBoxster is right on, top to bottom, use 1 chunk for the top half, 1 chunk for the lower (much dirtier), lots of soapy water or detailing spray, and the clay works well on the wheels as well, just make sure you strip off the wax if any on the wheels first....
1998 Guards Red Black/Black 5 sp.
Work done '06 :Replaced bad hose and clamps from reservoir tank
oil change and filter
replaced seals on both cam covers
brakes bled and refilled
Replaced bent rear right lower control arm
Front air dams and 3 underbody panels replaced
Halogen headlamps replaced
bigislandboxster is offline   Reply With Quote
Old 02-28-2006, 07:15 AM   #8
Perfectlap's Avatar
if you want to save some money look in the yellow pages for autobody supply stores and you can buy clay in bigger quantities and cheaper. All clay is essentially the same, there are patent issues preventing more companies from making their own clay. Most just add dyes and rebrand it. Sonus has a very soft clay that is intended for more frequent use. A little too soft for my taste.
Old 02-28-2006, 09:22 AM   #9
Perfect made an excellent point, there are different abrasive properties of clay. The Meguiars and Mother's Clay bars are good (i've used them many time before) you can also go to a specialty auto detailing store that sells all types of clay and they'll probably give you a little "tech" session on which one would work best for you and your car.
KRZ
Magnaflow Exhaust
