Old 04-29-2014, 01:26 PM   #1
korbeck's Avatar
Low RPM/Gear Engagement Squeak Noise
Hi y'all.
Another weird question here. Recently when coming to a stop and engaging the clutch with little to no gas I hear a squeaking noise until I accelerate.
This weekend I plan on removing the engine cover for the first time to check the belt, bearings, and water pump for drained fluid through the weep hole, although I haven't had to top off the fluid.
Any other suggestions, or ideas? It's like a weird squeaking noise until I give it a little gas or until I go. Happens on second gear to when rolling at a low RPM engagement. It also happens sometimes coming to a stop in neutral.
It also doesn't happen when driving from a cold engine. It happens mostly when the engine is warmed up a few minutes later.
I'm really suspecting the bearings and hopefully WD40 will help
Also what type of belt would I need if that is the problem, although I don't see how it could make that type of noise at low RPM.
Thank you for your patience and advice. It's a bit annoying to drive in stop and go Atlanta traffic constantly hearing that rhythmic eee-eee-eee noise 😂.
Also, I replaces my AOS last year November and my car has about 76k.
Thank you!
korbeck is offline   Reply With Quote
Old 04-29-2014, 01:29 PM   #2
korbeck's Avatar
Also noted is that I can replicate the noise again by putting my e brake on, and trying to engage the first gear at low rpm
Many thanks again. I'm quite the amateur mechanic.
Old 04-29-2014, 06:48 PM   #3
Does the sound occur if you just depress the clutch but do not engage first gear? Or do you have to press the clutch AND engage first gear?
Old 04-30-2014, 05:11 AM   #4
korbeck's Avatar
I have to press the clutch and engage first gear! It happens only for a little bit until full engagement
I'm really thinking belt, or belt tensioner, or even a bearing.
Wd40 hopefully solves it? 😋
Old 04-30-2014, 06:26 AM   #5
Multi-Boxer Driver
Deserion's Avatar
WD40 is not a lubricant. Just saying.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 04-30-2014, 12:46 PM   #6
lkchris's Avatar
WD = water dispersant
Sounds like a throw out bearing
Nothing about pressing clutch pedal and/or moving gearshift is related to serpentine belt or the tensioners.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Old 04-30-2014, 06:14 PM   #7
korbeck's Avatar
Thanks. Maybe some Teflon instead
Old 04-30-2014, 07:55 PM   #8
korbeck's Avatar
Thanks! I'll look into it tomorrow.
Sounds like an ims related problem potentially?
Sorry my mechanics aren't great. Lots of research for me tomorrow 😎
Old 05-05-2014, 03:16 PM   #9
korbeck's Avatar
I don't get it. It doesn't happen for like 10-20 minutes of driving. But it squeaks on occasion when I'm on neutral slowing down or at a stop. I'm not in gear or anything. I rev it to make it temporary stop and sometimes it stops. Other times it continues.
But when I engage really low I can hear it squeaking until the clutch fully grabs. But it shouldn't be relative to the clutch if it happens on idle...
The belt looks fine. Maybe I should replace it anyways?
Thanks for the help.
Old 08-03-2016, 10:00 PM   #10
Did you ever find out what the problem was? I have the same issue.
New clutch
New ims
New aos
New serpentine belt
Mine also seems to sqeak or cherp a little when rolling in neutral over a bump. That will cause it to cherp. Im guessing a pulley but would like more concrete evidence.
Mine also starts once the car warms up. If the rpms are high it goes away.
dcs9654 is offline   Reply With Quote
