04-21-2014, 12:23 PM
#1
Front license mount question
How are those two rubber shaped plugs that the license frame screws into attached to the front bumper? Are they a force fit that just pops in and out with a bit of pressure or is there some kind of screw fastener that holds them in place? Thanks in advance,
AKL
'02, Arctic Silver/Graphite Gray, 2.7, TIP, 2nd cat delete, Charlie Chan muffler,de-ambered, Braille Battery, clear tailights, painted bumperettes, clear third brake light, M030 sway bars, F shock tower braces, clear rear deck, '03 side vents.  15mm spacers fore & aft.
04-21-2014, 12:34 PM
#2
They are flare anchors. The screw flares the wedges out to retain the mount. Once screw is removed, they just pop out
04-21-2014, 12:44 PM
#3
Here you go...
04-21-2014, 03:23 PM
#4
If anyone needs a front plate mount, I have one (brand new) available for cheap + shipping. Don't mean to highjack, BFWIW.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
04-25-2014, 01:09 PM
#5
Thanks large. I want to see if I can turn them upside down to see if the plate will then slant a bit downward. Will let you know if it works.
AKL
