Old 03-06-2014, 09:31 AM   #1
Boxster S Bassist
About to do front brakes, what else at same time?
Would also replacing the front wheel bearings be good preventative maintenance? Brake hoses? Car is a 2000S with about 75K miles. Thanks.
John Bergen is offline   Reply With Quote
Old 03-06-2014, 09:43 AM   #2
Registered Boxster abuser
healthservices's Avatar
I tend not to get into things get just because I have nothing better to do.
The wheel bearings are sealed. You can replace the if they are not smooth when spinning. I usually do not even consider doing brake hoses until 120k.
Old 03-06-2014, 09:53 AM   #3
But I would flush the brake fluid. check the balance of the tires for wear, (dismount tires from wheels and cross rotate if necessary and possible) as well as maybe do an alignment.
Old 03-06-2014, 09:57 AM   #4
Perfectlap's Avatar
Not to sound like a broken record but are you on the most recent coolant cap from 2004? That's $20 that could save your engine. I would prioritize updating the coolant system in general.
I just did my rear wheel bearings at 90K miles. They were shot. I'm mean really bad.
Funny thing is I can't really tell or hear a difference with the top down, and my foot off the throttle.
But no bearing lasts forever.
Old 03-06-2014, 10:02 AM   #5
steved0x's Avatar
Yeah if you have the wheels off and messing with the brakes a bleed or flush is good. I can't really think of anything else up front.
For the back wheels there are lots of good things you can do with the wheels off, spark plugs/tubes is the one that springs to mind.
Steve
Old 03-06-2014, 11:32 AM   #6
  • Check all front suspension components, mounts, and bushings, including steering rack.
  • Spend $45 and install GT-3 brake ducts for better front brake cooling.
  • Check wheel bearings.
  • Check tires for excessive wear especailly on inside portion of the tire. This is often missed when inspecting tires on the car because the wear is not easily visible.
  • Check the front underbody panels to be sure that they are firmly mounted to the car and not flapping in the wind.
Old 03-06-2014, 12:09 PM   #7
you brake hoses are 14 years old... I would check them for cracks
Old 03-06-2014, 12:23 PM   #8
They're over $100 each according to Pelican!
'99 black 986
Old 03-06-2014, 12:33 PM   #9
steved0x's Avatar
[LIST]
I just got some a few weeks ago for $29.95 with free shipping off ebay; I have heard others say they got them for even less.
Porsche GT3 Brake Cooling Ducts 996 997 986 987 New Genuine | eBay
I haven't gotten around to installing them yet though...
Steve
Old 03-06-2014, 06:06 PM   #10
jsceash's Avatar
According to Ebay they are about $32 to $38 a pair
Old 03-07-2014, 05:57 AM   #11
Also, please replace the caliper bolts when you do brake pad change... the bolts stretch over time and it's just cheap insurance.
http://www.****************************************************.com/product/99907340201.html?Category_Code=98625brakesGPRR
Old 03-07-2014, 06:01 AM   #12
Not to get confused... there are GT3, GT3 Cup & GT2 brake ducts...
GT3 street car brake ducts are $30 a pair.
GT3 Brake Duct Spoilers:Porsche Parts & Porsche Accessories - Wholesale Porsche Parts & Tequipment
Want GT2 set? $325 a pair. I guarantee you they'll be ripped on the street within the first 500 miles since they're so low.
GT2 Brake Duct Spoilers:Porsche Parts & Porsche Accessories - Wholesale Porsche Parts & Tequipment
Old 03-07-2014, 06:09 AM   #13
mikesz's Avatar
I replaced pads, rotors, sensors on all four corners. Flushed brake fluid, painted calipers. I have a 99 and had water in the brake booster so i replaced the master cylinder and booster and installed the update kit so no water gets in the boostere anymore. Its a PITA but cannot fathom what the labor would cost me at the local dealership. The update kit only applies to pre-2000 cars.
99 Porsche Boxster
Old 03-07-2014, 09:51 AM   #14
DIY extremist
black_box's Avatar
I wouldn't mess with the bearings unless you have to. They'll let you know (screeeech!) when it's time. The rears will go first.
"Betty" -- 2000 Boxster S, Triple Black, loaded except PSM (sold to a good home)
"Veronica" -- 2008 Boxster S, Arctic Silver on Blue
"Maleficent" -- 2007 Cayman S, Red and Black, TPC Turbo 3.6L 460 RWHP, H&R RSS Coilover / TPC stage 2 suspension
black_box is offline   Reply With Quote
