Old 01-07-2014, 01:15 PM   #1
BIGJake111's Avatar
Weird noise when exiting neighborhood
Whenever I leave my neighborhood and only then when I make the shard right there is a strange noise from the rear right of the car.. It sounds like a large metal teter totter or something. This is the only place I ever hear the sound what could it be?
Old 01-07-2014, 02:20 PM   #2
One solution would be to move to a different neighborhood!
Actually, right rear could be track arm bushings, a heat sheid (cat). Hard to tell without hearing it.
Old 01-07-2014, 03:36 PM   #3
BIGJake111's Avatar
Sounds like a slight squeak only happens on the first turn from start each time I start the car.. Maybe something's just cold
Old 01-07-2014, 05:57 PM   #4
noise
I can assure you that this is not your first rattle , squeak ,knock you will hear! To soon to tell yet as far as the current noise. heat shields rattle, squeaks are more suspension, like control arms. If noises bother you as they do me as well as many others then this forum surely helps but recently I chase my own rattles because never seems to replicate well at the shop plus these cars are not space shuttles. EASY TO WORK ON SUPRIZINGLY
nicecar is offline   Reply With Quote
