Old 10-25-2013, 09:55 AM   #1
epapp's Avatar
Why would these MAF wires be spliced?
Cleaned the MAF yesterday, noticed the PO had the red and blue wires spliced. Doesn't look like they are spliced into anything anymore, but what WOULD they have been spliced into? I can't think of anything you would want to splice into the MAF wires.
Old 10-25-2013, 10:13 AM   #2
They don't look like splices, they look like clamp on wire taps where someone had something attached.
Old 10-25-2013, 10:19 AM   #3
Jager's Avatar
Voltage testing??
Jäger
300K Mile Club
Old 10-25-2013, 10:26 AM   #4
More likely one of those A/F "tuner boxes" used to lie to the DME about what is really going on in an attempt to eek a couple of HP out of the car.
Old 10-25-2013, 11:06 AM   #5
epapp's Avatar
Right, they are taps...splices...same thing.
I suppose it could have been something like the resistor trick...eek
Old 10-25-2013, 11:44 AM   #6
Shehadehd's Avatar
I'd expect someone to try something like that on an old Beamer but not Porsche... Weird
If you are interested in a Comfort-Top module, please visit:
https://www.enhancedautomods.com/shop/comfort-top
Shehadehd is offline   Reply With Quote
Old 10-25-2013, 12:15 PM   #7
Nine8Six's Avatar
Yep that's what some tuner needs to get a spot on job done on a cheap porsche Got it on my 986.... 50K POT and 50kohm resistor is all you need. Safely hiden in the cabin/console compartment.
Magic weapon lol
Old 10-25-2013, 12:17 PM   #8
epapp's Avatar
haha....you mean like when I chipped my bmw? Thats totes different...a chip versus a chinsey resistor
Old 10-25-2013, 01:00 PM   #9
Shehadehd's Avatar
Magic weapon lol
Hahaha, not sure if you're joking.... ?:/
Old 10-25-2013, 01:13 PM   #10
Nine8Six's Avatar
fooling downstream vortex vibrations?? hacking your O2?? spring rates on the larger TB?? Nah?! Now that's what freedom means +525 horses minimum! Oh and Chinese Made Tires!
I was sure that you guys had it all sorted already.
Old 10-25-2013, 01:32 PM   #11
Shehadehd's Avatar
Haa!!! Beat you on the tires. Homemade... 100 grit sandpaper... Don't even need snow chain anymore.
Old 10-25-2013, 01:33 PM   #12
drew44's Avatar
Had found something similar to that on my 2001 Boxster, where the wire had been tapped like with a voltage tester. It was so bad I had to replace the entire wiring for the MAF connector, and the only way to do that was to purchase the entire wiring loom.
drew44 is offline   Reply With Quote
Old 10-25-2013, 01:38 PM   #13
Nine8Six's Avatar
Oh hang on, not too fast...
My tires are so goddamn cheap they "melt" after a good heat cycle. 100 times more sticky than Performance tires, and 100 grit That's how it done
Old 10-26-2013, 08:01 AM   #14
ChrisZang's Avatar
Like! Like! Like! Like! Like! Like! Like! Like! Like! Like! Like! Like!
Old 10-26-2013, 08:11 AM   #15
epapp's Avatar
I think you guys should post in the cheap tires thread haha
Sent from my iPhone using Tapatalk - now Free
Old 10-26-2013, 10:07 AM   #16
epapp's Avatar
And to think I was just about to put one of my spare log taper 50k pots in.
Old 10-26-2013, 08:22 PM   #17
Shehadehd's Avatar
I'm not the one of fills my tires with nitrogen....
