Old 10-25-2013, 10:46 AM   #1
epapp's Avatar
Teeny fluctuations in idle
Ive seen similar fixes for fluctuations in idle like the idle air valve (99 non e-gas) and I've already cleaned that.
My idle will fluctuate maybe 50-100rpm when sitting at a stop light or just stopped in general. Are there any other things to check for idle fluctuation?
Old 10-25-2013, 11:24 AM   #2
Mine went away when I changed the O2 sensors.
Wret is offline   Reply With Quote
Old 10-25-2013, 11:27 AM   #3
Jager's Avatar
Did you clean the throttle body? Remove the intake tube and look inside the throttle body, around the butterfly, to see if there is a black build-up (coking). That build-up will interfere with air flow and the throttle position sensor at idle will not be nominal.
Jäger
300K Mile Club
Old 10-25-2013, 12:08 PM   #4
epapp's Avatar
Yes I took off throttle body, cleaned it completely etc.
So the only few things to look out for is idle air control, throttle body, and O2 sensors? If it was an O2 sensor giving a bad enough lambda, wouldn't I get a CEL?
Old 10-25-2013, 12:11 PM   #5
Mine eventually did give a CEL but the idle fluctuation started long before that.
Old 10-25-2013, 03:33 PM   #6
golonaus's Avatar
got the same thing on my 99
clean TB and ICV
new MAF
which O2 r we talking??
99' with 3.4l engine. ROW tune. SAI delete
Old 10-25-2013, 06:14 PM   #7
I have the same thing in my 2000 S, havent do anything yet to fix it...
peterek is offline   Reply With Quote
Old 10-25-2013, 09:32 PM   #8
epapp's Avatar
clean TB and ICV
new MAF
Do you mean you cleaned the TB and ICV and it fixed the problem?
Sent from my iPhone using Tapatalk - now Free
Old 10-25-2013, 09:49 PM   #9
golonaus's Avatar
cleaning didnt solve it 4 me
But I belive my 02 sensors are original
Old 10-26-2013, 05:16 PM   #10
Same on my 2000 S - the tach flutters about half of its width at idle.
Old 10-26-2013, 08:26 PM   #11
epapp's Avatar
About half the needle width? Yeah that's exactly what I'm talking about. I suppose if it's happening on egas and non egas models then it's probably not my ICV.
