Old 09-24-2013, 11:25 AM   #1
RBrummer's Avatar
Need advice on Boxster oil leak
I have a 2000 Boxster S, 104,000 miles, purchased about 6 months ago at a good price. Did a PPI, a few normal leaks were noted. After I purchased the car, I had an independent mech replace IMS bearing and RMS plus some other misc stuff.
It still had a small oil leak. Dealer said RMS, a second independent mech said RMS, my original independent said can't be RMS. Took it back to original indep mech and he mounted a camera under the car and test drove it- it appeared the IMS seal was leaking. He pulled the transmission (Tip) and redid the IMS seal, even though it appeared to be dry. Buttoned her up and test drove her and she still leaked.
Finally, upon further review, he found a leak in the seam where the two parts of the engine case the case bold together, right by the IMS.
So, now we know the source- either a seal or the case is porous.
Options?
1. Live with it- it doesn't leak much at this point probably less than a quart every thousand miles.
2. Use a heavier oil
3. Trade it in
4, Rebuild motor
5. Find a used one and drop it in.
Suggestions?
RBrummer is offline   Reply With Quote
Old 09-24-2013, 09:49 PM   #2
RawleyD's Avatar
I would "Live with it"..
but what do I know?, I'm a noob.
:ah:
Old 09-25-2013, 07:36 AM   #3
Mobile Porsche Surgeon
kashmir's Avatar
Have your mechanic check with a go not go tool, Porsche made engine's with crankshaft carries that were not concentric to the block.
Mike's Specialty Porsche Service
Mobile Mechanic Specializing in Porsche and Select Automobiles
http://www.mikesspecialtyautomotiveservice.com/index.html
Early 1996 / 97 Boxster, 130 k, De snorkeled, IMS, Top Speed Headers.
kashmir is offline   Reply With Quote
Old 09-25-2013, 08:02 AM   #4
Same exact thing happened with my 02 base. Same diagnosis, except made by me.
It's a common occurance. Some people recommend replacing the case pinch bolts in that area which I didn't know about when I did my IMS/RMS project.
The seepage probably amounts to 1Q/20,000 miles, may be a lot less. Just live with it. No big deal.
seventythree is offline   Reply With Quote
Old 09-25-2013, 11:31 AM   #5
Trey T's Avatar
What's the tool check for exactly? Is that a precision machined part?
Trey T is offline   Reply With Quote
