09-21-2013, 08:36 AM
I am my own mechanic....
100k club, check in!!
128,500 or so. Runs great. Not one bit worried about mileage, daily driver.
Will do shift lever leak, clutch, IMS this winter, then we're in top shape.
Who else ain't so bothered by mileage??
'08 VW Touareg T-3 wife's car
09-21-2013, 08:45 AM
My 2002 S at 165k. IMS changed at 145k. Had no signs of wear.
2008 Boxster S PDE2
09-21-2013, 08:55 AM
133,000+ miles. Purchased 3 months ago, already put over 7,000 glorious miles on her. I take the long way to work each day now, with extended weekend trips.
Two oil changes : first found small brown nodules in filter, less then 1mm in size, and 1 very thin sliver of metal. My specialist said brown nodules are normal and from timing chain guide, and the sliver if metal is aluminum, so not the IMS. Second change filter looked much better; keeping them at 3000 miles. Changed transmission oil, which was a beautiful metalflake gold color; just something you hate seeing in a car however. Probably never changed, and a definite improvement. Still need to do all the basic's of plugs, brake fluid and coolant flush, other filters. Drives magnificent!
Hope to get to 150,000 miles by next summer!
09-21-2013, 09:07 AM
106,000 miles. 2003 S. On my third water pump, second fuel pump and replaced both window regulators at different times. Other than that, no issues. I am in my fifth year of ownership and it is my daily driver.
09-21-2013, 10:18 AM
Amateurs…
Jäger
300K Mile Club
09-21-2013, 10:21 AM
Originally Posted by Jager
Amateurs…
I almost renamed the thread to exclude you specifically.
Start your own thread all by yourself!
We're mid-lifers.
09-21-2013, 10:37 AM
Need For Speed
105k miles, bought with 97k miles, owned since Feb 2013. All I have had to do so far is regular maintenance and rear tires. Planing IMS Retrofit, some exhaust mods and suspension pkg..
09-21-2013, 10:58 AM
132k, bought with 131k.
These last 1k have been bliss! lol
:ah:
09-21-2013, 11:39 AM
142k miles and still strong.....driver /track car
Kevin
01 Boxster S
02 S Hulkster
09-21-2013, 12:22 PM
Have you done the IMS upgrade on your 01 S Kevin?
09-21-2013, 03:45 PM
120K. still in love.
-Tuan
tuanle16@juno.com
09-21-2013, 04:23 PM
01 only has 35K ....the 02 track car 142K ...no IMS ....... when I do a clutch or freshen the engine I will take care of that while I'm at it
Kevin
01 Boxster S
02 S Hulkster
09-21-2013, 07:13 PM
104,000 on 1998 IMS guardian installed. No metal in the filter yet. Lots of little things fixed, rather routine with the exception of CLU! We drive it pretty hard.
09-21-2013, 07:18 PM
131K on my 2001 Base, bought it with 114k in Feb 2012. Mostly routine stuff, starter, AOS, tires, front suspension refresh. Oh & replaced the old faded tan top with a new black one.
09-21-2013, 07:27 PM
Multi-Boxer Driver
Well, I'll be in the club in about 3700 miles.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
09-21-2013, 07:52 PM
[Tom Bodett]We'll leave the light on for you.....[/Tom Bodett]
09-21-2013, 09:06 PM
2000S with 108k. It had 103k when I bought it in December. I love it! I had the ln double row bearing put in and previous and owner took really good care and fixed all the stuff like aos, maf, ignition switch, and new clutch. I'm loving it!
Steve
Edit to provide additional information. I have service records going back around 50,000 miles.
103,000
LN Engineering double row IMS bearing retrofit
100,896
Bank 1 precat oxygen sensor replaced
Replaced fuel and oil caps due to cracked seals
97,637
Clutch replaced, clutch assembly disk, pressure plate, and throwout bearing
Ignition switch replaced
Parking brake switch replaced (top not working)
AOS Replaced
RMS Seal replaced
IMS Seal replaced
Sometime within the last 20,000 miles (I don't have that one in front of me)
Front engine mount replaced
When I find that folder I will update here with more info, there is also some regular maintenance like spark plugs.
I do not have a record of the water pump ever being replaced.
09-22-2013, 07:21 PM
How long have you had it? How do you drive it? TIA!
09-22-2013, 09:41 PM
Had the car since 2006. Previous owner drove long distance a lot. It was daily driven for me but hardly any traffic. My son has it now and daily driven but only 10 miles each way.
2008 Boxster S PDE2
09-22-2013, 10:41 PM
I'm from Antioch....
