Old 08-28-2013, 11:24 AM   #1
mountainman's Avatar
crankcase pressure
When I remove the oil filler cap with the engine running the idle increases. Is this normal or an indication of something maybe a bad aos?
mountainman is offline   Reply With Quote
Old 08-28-2013, 11:50 AM   #2
I'm pretty sure if you remove the oil Cap the idle changes. if you find that there is a massive vacuum when you put your on it then its probably a bad AOS.
01 Boxster - Lapis Blue - Aerokit II Daily Driver.
98 Pontiac sunfire - Winter beater- TRADED IT IN FOR 200 DOLLARS
2010 Honda Civic Coupe - Gunmetal Grey - Lease ended and returned
2011 Mercedes Benz GLK350 - Gunmetal Grey
ramo80 is offline   Reply With Quote
Old 08-28-2013, 12:34 PM   #3
Normal crankcase vacuum level is about 5 inches, when the AOS fails it jumps near 20, which makes getting the cap off a chore.
Old 08-28-2013, 12:39 PM   #4
There doesn't seem to be a really strong vacuum when I cover the filler opening, but there is a definite difference in the idle when I open the cap.
Old 08-29-2013, 01:04 PM   #5
jb92563's Avatar
That would be normal with any car that uses vacuum to influence various things with the engine.
The computer uses vacuum to gage throttle response, idle etc.
By opening the cap you are breaking the normal vacuum and things will change.
