Old 08-13-2013, 02:40 PM   #1
Won the Porsche Lottery Today
Pulled into a parking lot, coasted around the corner and with no warning at all the engine died. Put it in neutral, cranked it to hear one second of the most gut wrenching sound in the world.
I change the oil every 5K w/Mobile1 as directed, examine the filters and they've been free of debris but I was due for an oil change. There are no fluid leaks, no noises. It's a 2004 S with about 52,000 on it.
Thanks Porsche.
Foydawg is offline   Reply With Quote
Old 08-13-2013, 03:01 PM   #2
jakesbox
trimer's Avatar
Damn man...I hope it's nothing real bad...
When are you taking it in? Keep us posted
Old 08-13-2013, 03:10 PM   #3
Chuck W.'s Avatar
Ugh... I hate these post. Hang in there and keep us posted.
1995 Porsche C4 Cab
Old 08-13-2013, 03:24 PM   #4
Pull the oil filter to check for metal. If there is metal, then drop the sump plate and see if there is any metal debris in there. If there is a lot of metal, well you have problems. If little to no metal, then remove the drive belt and turn the motor over by hand, clockwise only. If there is major damage, you will feel the interference. Don't force anything. I would probably pull the plugs before rotating by hand, it will be much easier to feel interference if there is no compression. If it locks, well you wil have to take the motor apart at that point.
If it rotates easily, I would start by pulling the cam end plugs to check if the cams are still in timing. If its still in timing, pull the cam covers to see if you have a bad valve, look for sheared lifters.
What kind of noise was it making? Was it a deep rapping sound (probably a bearing) or a rat tat tat (probably a valve).
Good luck.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 08-13-2013, 03:36 PM   #5
I had it towed to a local indie (Stuttgart Specialties in Louisville, KY) as that sort of work is beyond my skill level. There was no sound prior to the stall. I'd describe the horrifying sound emitted during the second or less I cranked it was one of large parts flopping around, not small ones.
Old 08-13-2013, 03:57 PM   #6
thom4782's Avatar
Bummer.....
If the IMS let go, you're within the 10 year "settlement" window with a 04 model. Just make sure you follow the criteria for the repair and filing of the claim.
Old 08-13-2013, 04:04 PM   #7
Check the water pump. Mine went out and it made the most awful sound that I thought was IMS. Not sure if a water pump death can cause an engine to die - but just offering a suggestion.
Old 08-13-2013, 04:30 PM   #8
Perfectlap's Avatar
How many miles did you have the car? Did you do the LNE IMS swap?
Granted many done for engines are wrongly atttributed as IMS fail.
BORN: March 2000 - FINLAND
Old 08-13-2013, 04:34 PM   #9
I will light a votive candle tomorrow for you in hopes it is something other than the IMS. You took it to a good shop, I've heard others in your area speak highly of them.
Coincidentally, got to talking to the cleaning guy at our office tonight before leaving work, he pulled in in a used 2nd generation Miata. Pretty good looking car with 150k on the clock, he said it has run like a top for the couple of months he has owned it, paid $2500 for it.
He then went on to tell me about the incredible deals to be had on used Boxsters, I sat back and let him educate me for a few minutes. Since I had to leave I let it drop and said I'd talk more to about it next week, he's a good guy but I know that a scenario such as this would be completely devastating to his wallet.
Good Luck Foydawg.
Old 08-13-2013, 04:59 PM   #10
Granted many done for engines are wrongly attributed as IMS fail.
No preventative swap and it has about 52000 miles on it.
It's my impression oil leaks leading up to an IMS failure and post-failure are typical and I haven't had seen either. Mine is a Tiptronic if that makes a difference in allowing the oil to hit the ground vs. a manual.
patssle has me hoping it's not that serious.
Old 08-13-2013, 06:26 PM   #11
Lottery
never played the lottery till i bought an 02 s 88k from brumos then did my research, as the brumos mech. said " cosmetically its a beautifull car"! car now has 113 k and i play the lottery all the time... but now jake has me stressing on the lifters oh well i guess alot of people would love
to have my lottery ticket
nicecar is offline   Reply With Quote
Old 08-13-2013, 06:42 PM   #12
fullthrottle52's Avatar
Foydawg,
I live in Louisville and have all my work done at Stuttgart. I've been using them for almost 3 years. They will sort it out for you. Hope it is good news for you. I have a 2000 with 68,000 miles and have not had the IMS bearing done. We all hate hearing about these issues. If you need any help let me know.
2000 Boxster - Loved and sold
1999 911 Cabriolet - Also loved and sold.
fullthrottle52 is offline   Reply With Quote
Old 08-23-2013, 10:42 AM   #13
Thanks Porsche.
UPDATE: It is an IMS failure and as a non-CPO second owner car, I theoretically would be eligible for 25% coverage under the class action suit BUT, since Porsche says my 2004 Boxster S was "put into service" on 7/4/03, it's over 10-years old and not eligible - EFF Porsche!
Old 08-23-2013, 12:00 PM   #14
Damn Yankee
TeamOxford's Avatar
Please don't give up so easily. Six weeks outside the "window" is an extremely short time. A personal appeal to the right people at Porsche may result in some concessions.
Determining who the "right people" are will be the challenge. Like people who could not afford bad publicity from a disgruntled owner about their hallowed marque.
If done objectively and with a modicum of class, it just might work.............
TO
Old 08-23-2013, 12:12 PM   #15
Absolutely stinks.
I gotta tell you, I love my 2000S (112K) and have had great 'luck' with the car. It's at a price point that I think I could stomach it if the motor took a crap. I love the look of the 987's and the new 981's but am unwilling to play the lotto with more $$ on the line.
It's funny. We picked up an '04 350Z roadster a month ago for my wife. The car has right at 100K miles and for some reason, it doesn't scare me at all! Time will tell.
Old 08-23-2013, 01:20 PM   #16
mountainman's Avatar
been there, so I know how disappointing it is. Waiting to see if Porsche really does follow thru. I was out 20K for the new engine and am eligible for the 25%. I know what you are going thru trying to decide whether to put in a new engine or shop for a new car.
mountainman is offline   Reply With Quote
Old 08-23-2013, 02:57 PM   #17
Perfectlap's Avatar
Sorry to hear that. How many miles did you get out of the car (minus previous owner mile) before it went kaput?
Mind sharing what you paid?
Old 08-23-2013, 03:05 PM   #18
I paid about $24K for it in late 2010. It had 23,000 miles at the time. I've put about 29,000 miles on it.
Old 08-23-2013, 03:07 PM   #19
TO
Good advice. I submitted an inquiry with the attorneys that won the class action. My local dealer, Bluegrass Motorsports, simply referred me to 1-800-PORSCHE.
Old 08-23-2013, 04:07 PM   #20
Absolutely stinks.
I hope it's an 04.5 350Z. The younger ones had tons of problems. I had an 03 and it was the only time I've had a manual tranny or clutch blow....and it happened 4 times due to design flaws on both the clutch and tranny. Problem went away when they upgraded me to 05 tranny and clutch assembly.
I wasn't worried about any sort of Porsche lottery and was blissfully ignorant (having loads of fun driving it) until I started reading this forum after I bought mine on the last day of June. Now I'm paranoid as hell and have never done so much preventative maintenance on top of having AOS go out after 3 weeks of ownership and then a significant leak around the driver side bank. I've gotten real good with the 4 jackstands and still love the car, though...
I should have taken out stock in Pelican parts in hindsight...lol
reiver is offline   Reply With Quote
