Old 08-23-2013, 10:13 AM   #61
My '97 with 103K mi had the original cap AND had previously (to me) had the water pump and tank replaced. In addition, my mechanic looked everything over and did not mention it first...point being not "everyone" shares the concern with using the original cap. I agree with the logic to replace it and requested that my mechanic change it at the last oil change.
runjmc2 is offline   Reply With Quote
Old 01-17-2014, 02:15 PM   #62
Perfectlap's Avatar
^ smart. and Friday bump. We must have a lot of new Members since thread start.
Old 01-17-2014, 03:10 PM   #63
heliguy's Avatar
Original...
Old 01-17-2014, 04:09 PM   #64
jsceash's Avatar
I believe it's original. the only one I've had
Old 01-18-2014, 08:04 AM   #65
doragman's Avatar
original...on a 99
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 01-18-2014, 03:04 PM   #66
2004 Boxster S
evan9eleven's Avatar
New version of the cap at 73,000 kms, along with preventative maintenance: water pump, thermostat and coolant tank (among a dozen other things.)
evan9eleven is offline   Reply With Quote
Old 04-25-2014, 02:33 PM   #67
Perfectlap's Avatar
Friday bump...
And replace your gas cap too. I think it got rid of a CEL that kept coming up.
Old 04-25-2014, 04:08 PM   #68
Boxster S Bassist
Replaced it with the new version on my 2000S at 66K miles. Car was overheating before that.
John Bergen is offline   Reply With Quote
Old 05-16-2014, 02:02 PM   #69
Just had a slight trail of coolant when pulling into the garage, condensation at the trunk, and I noticed the past 1-2 years, I was topping off with distilled water (not much, less than 1/2 cup).
Ordering from Suncoast right now...you guys rock!
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
Old 05-16-2014, 05:20 PM   #70
Tucker2's Avatar
Thanks for this thread guys. I have this issue and an 01 cap. I'll be ordering a new one this weekend.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 05-16-2014, 07:08 PM   #71
eicheldp's Avatar
Started getting condensation in the trunk and replaced the original cap on my 2004S with 16,000 miles. Trunk is now free of condensation.
2004 Boxster S
eicheldp is offline   Reply With Quote
Old 05-18-2014, 06:49 AM   #72
On my second 04 version coolant cap. Caps seemed fine, just replaced them hoping to eliminate condensation.
Have always had condensation. No loss of coolant or overheating, except when water pump fails.
And I'm on my fourth water pump. Worn impellers each time.
100,000 mi 2000 base.
jotoole is offline   Reply With Quote
Old 05-18-2014, 07:07 AM   #73
I am my own mechanic....
Timco's Avatar
Had condensation over the cap area. Swapped cap a year back. Blue one. No condensation since.
'08 VW Touareg T-3 wife's car
Old 05-18-2014, 08:26 AM   #74
Still have condensation, albeit very little.
Old 05-20-2014, 01:38 AM   #75
Yikes! 4 water pumps in 100k miles? How did you know water pump failed each time, did you wait for it to overheat, or trail of coolant leaking under the car?
I am on my original water pump with 80k miles, 02 base.
Thanks.
Old 05-20-2014, 06:07 AM   #76
OKCShooter's Avatar
2002 w/80K...Original Cap
OKCShooter is offline   Reply With Quote
Old 05-20-2014, 08:42 AM   #77
Coaster's Avatar
Replaced mine at 95k with water pump (which was beginning to leak) and coolant.
Coaster is online now   Reply With Quote
Old 05-20-2014, 10:06 AM   #78
03 Boxster 2.7 tip .
142k on original 02 cap
09 carrera 4s pdk .
65k on original 03 cap
Ian c is offline   Reply With Quote
Old 05-20-2014, 11:40 PM   #79
Glad this thread was refreshed - after putting down my beverage I took a stroll out to the garage and noticed that my cap was an .01 part number. For a minute I was impressed that I have 88K miles on my '98 Boxster and I'm still on the original cap...then I started to recall that there was some work done on the system by the previous owner....
So that got me looking through the maintenance records I received with the car. Sure enough - in 2005 with 36K miles the reservoir was replaced and a new cap was included.
What I find odd is the service record has the new cap as having the part number of .04....and I somehow have a cap with an .01 part number?? Did they have the .04 cap in 2005?
Regardless - even if the cap was replaced a 2nd time with an original .01 part number cap...I will now be ordering the .04 cap...
SpikeJr is offline   Reply With Quote
Old 05-21-2014, 08:27 AM   #80
Perfectlap's Avatar
Smart. Our resident mechanic says his shop toss any that don't hold a minimum presure of 18 PSIG if I recall. Seems to me that if you flush as a DIY without vac fill and have a cap not holding enough pressure you'll like split the original coolant tank via trapped air or worse you'll bake up a fresh batch of hot pockets and burn your tongue.
