Old 08-12-2013, 12:16 PM   #41
HammerESQ's Avatar
I'm glad to hear that's all it was, and your car is back to perfect. If you don't mind me asking how many miles do you have on the coil packs? I replaced mine ~ 90K as a 'while you are in there' job when I was doing my clutch, IMS, RMS, and 90K service. What I found was shocking, all 6 were cracked, these are the worst two:
I've got to figure being low on the engine and somewhat exposed to the elements doesn't help the survivability of these.
HammerESQ is offline   Reply With Quote
Old 08-12-2013, 07:27 PM   #42
Carnut
AndyA6's Avatar
Don't mind at all, 56000 mls.
Those coil packs look naaaasty!
'14 Boxster
Old 08-12-2013, 07:55 PM   #43
HammerESQ's Avatar
The scary thing is the car ran just fine. I just figured at $30 each I should replace them while I was in there pulling plugs anyway.
Old 08-13-2013, 06:40 AM   #44
Hammer, where did you get them for $30.00? The best prices I was able to find were:
Set of 6, Porsche, $312.00 at Suncoast
Each, OEM, $39.50 at Pelican.
Brad
southernstar is offline   Reply With Quote
Old 08-13-2013, 07:00 AM   #45
HammerESQ's Avatar
My shop owner friend was able to order them from World Pack for something like $32 each. You might want to check with your local shop owner, they might be able to help you out.
Old 08-13-2013, 10:39 AM   #46
Thanks Hammer.
Brad
