05-18-2013, 04:01 PM
Gas Cap Tether: installed correctly?
My car came with a gas cap w/o the strap or tether. I bought a new cap and the required rivet from Pelican, but then wasn't sure how to properly install it. Yeah, I know, insane. Anyway, is this correct? --
05-18-2013, 06:03 PM
Looks like it's correct. However, my rivet mounts in a different spot. (2004 base)
05-19-2013, 06:42 AM
INCORRECT.
The rivet is in the wrong hole.
If you post a pic that shows more, I can point out the proper mounting hole.
05-19-2013, 12:51 PM
Originally Posted by seventythree
INCORRECT.
Thanks. Take your pick:
05-19-2013, 02:58 PM
Found this on Pelican Parts blog, showing the correctly position.
05-19-2013, 03:14 PM
THe other option, if your MY doesn't have that hole:
05-19-2013, 03:22 PM
That's it. Here is how it looks on my 2002:
05-19-2013, 04:17 PM
Thanks! Unfortunately, my car doesn't have a hole in the location shown above. I guess I'll just leave it as is. Thx again.
05-19-2013, 04:50 PM
Mine is set up exactly as yours is, as long as it works - problem solved.
05-20-2013, 10:00 AM
Has anyone had to change the locking mechanism on the gas fill door? Mine doesn't lock when I lock the doors like it's supposed to. Haven't seen the part anywhere and don't know how hard it would be to change.
05-20-2013, 03:52 PM
I had the same problem with my 1999. When I put the rivet in the hole under the clip, the lid wouldn't close. I then used a flat head bolt and nut in the same hole and the problem was solved. I like the solution grtc68 used. I was wondering what that screw to the left of the gas cap was for? I think I'll switch to his solution.
05-20-2013, 06:25 PM
Yeah, I ended up moving mine to that location. Works fine. Thanks all, esp grtc68!
