Old 12-14-2005, 08:40 PM   #1
deliriousga's Avatar
No heat. Any suggestions?
After my company's Christmas party tonight, we were coming home in freezing rain. Once the engine was warmed up, I noticed the air was still pretty cold. The windows were not defogging, so I started messing with the controls. I cannot get the heat to come on at all and the defroster vents on the dash will not blow. 45 minutes later I pull into the garage with a windshield that's iced up and a wife who resembles a grape popsicle.
Has anybody dealt with this? Does the heater valve in the Boxster fail in the open or closed position?
I'm going to start simple with fuses and relays, but wondering if there's a magical fix out there that someone has run into.
TIA!
1966 Wife White/Brown Top
Old 12-15-2005, 06:08 AM   #2
tqtran's Avatar
I've never actually heard about this with Porsche but I do know that this is a common problem with Jaguar XKs. It almost always due to the heater coil and some plastic bits melting.
tqtran is offline   Reply With Quote
Old 12-15-2005, 06:45 AM   #3
try to play with the ignition key
I have experiences too,
Try next, push very gentle counterclockwise your ignition key, so that it will come a little bit backwards, but not so much so that it will come to II position and stop the engine. In my humble opinion this is have something to do with a loosen contacts, but I can be very wrong.
Sincerely yours
z
zagit is offline   Reply With Quote
Old 12-15-2005, 07:27 AM   #4
John, you know, it might just be your ignition switch going out, but if you've replaced this recently it's probably the heater core.
Old 12-15-2005, 12:28 PM   #5
I replaced the ignition switch about 6 months ago so hopefully that's not the problem. I did find there is a heat actuation relay in the bank so I'm going to replace that tonight and see if it does anything. Otherwise, like you say, I'm afraid it's the core.
Old 12-15-2005, 12:57 PM   #6
Pilot2519j's Avatar
Lightbulb
It has not happened to me with the Porsche but with my Audi it was the thermostat(in the radiator) gone bad.
Pluralitas non est ponenda sine neccesitate
Pilot2519j is offline   Reply With Quote
Old 12-15-2005, 02:19 PM   #7
Are you talking about the coolant temp sensor?
I was also considering the interior temp sensor since that has been a problem with others in the 928, but it usually gives you an always hot situation.
Old 12-15-2005, 04:14 PM   #8
Talking Problem solved!
It was the "Actuation Heating" relay (#18). Replaced it and the defog vents work now and everything is toasty again. I love those $5 fixes!
Thanks!! :dance:
