Old 12-17-2012, 05:48 AM   #1
tanque55's Avatar
Where is it coming from?
Any help in finding out where the leak is coming from from these water marks would be appreciated. After a heavy rain both door carpets wet soaked below the speakers.
tanque55 is offline   Reply With Quote
Old 12-17-2012, 06:58 AM   #2
oc-boxster's Avatar
i get the same leaks but not nearly that bad when i wash my car-i was assuming it was that lower window seal
oc-boxster is offline   Reply With Quote
Old 12-17-2012, 07:17 AM   #3
thom4782's Avatar
Given the leak location, my best guess is one of these two parts (or both) is defective:
  • 996 537 532 05 - sealing for door slot
  • 996 537 532 06 - inner gasket
If the leak begins just behind the windshield, then it might be: 986 537 077 02 windshield frame gasket
Old 12-17-2012, 08:18 AM   #4
tanque55's Avatar
Thanks for the input, are those only available from the dealer or are there after market for them?
Old 12-17-2012, 08:20 AM   #5
Just replace the weather stripping around the window on the convertible top.
I get leaks from that location when the door is open. Luckily the weather stripping does it's job when my door/window is closed.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 12-17-2012, 09:58 AM   #6
Theoretical propagandist
Eric G's Avatar
The "weather stripping" you are talking about is a $1200.00 dollar item as it is integrated into the top seal. This is not a cheap venture if you choose to go this route. If you think I am kidding:
Pelican Parts - Product Information: 986-561-927-01-OEM
Old 12-17-2012, 10:40 AM   #7
thom4782's Avatar
The parts I suggested looking are not the weather stripping associated with the convertible top. They are either on the door or the windshield pillar. Still, they are expensive - a couple of hundred bucks each - as the Pelican Parts site shows
I'd call up a couple of Porsche specialty dismantlers first and see what they have to offer.
