Old 10-27-2005, 07:26 AM   #1
Brucelee's Avatar
Jim is dead on. The Box drains the battery pretty quickly and the factory battery is no star for sure.
Old 10-27-2005, 07:34 AM   #2
Where can you get a battery maintainer, and about how much do they cost? Is there a specific type to get? Here in Seattle, the weather is pretty crummy, so I plan on hibernating my boxster for the winter... More info please.
D.L. is offline   Reply With Quote
Old 10-27-2005, 07:45 AM   #3
Hi,
Here is the one I have used for the past 5 years. It's only 1 Amp, so it is very gentle on the battery. It only charges when the Battery demands it, but sends minute pulses to the Battery which prevents the formation of Sulphates. Hope this helps... http://www.vdcelectronics.com/batteryminder_12v_1a.htm
Happy Motoring!...Jim'99
Old 10-27-2005, 05:29 PM   #4
donv's Avatar
I've gone for over a month in warm weather and it was fine, albeit just a little noticeably slower on the cranking that time. Stock original battery.
OK, no cracks about the long Boxsterless spell - was on travel for business back to back.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 11-06-2005, 03:12 AM   #5
olly986
Guest
Posts: n/a
one thing you should never do is open your hood while the engine is not running, this will kill your battery and is apparently the most common fault boxster owner do!!
Old 11-06-2005, 07:03 AM   #6
Brucelee's Avatar
I have not found this to be an issue. Please elaborate.
Old 11-06-2005, 12:40 PM   #7
olly986
Guest
Posts: n/a
well i fought that it is obvious that you are pulling a lot of amps when opening and closing your hood, my porsche specialist definitely recommend to have your engine running when activating your hood I guess he knows better than me
