Old 11-24-2012, 01:28 PM   #1
Windows won´t go totally up with top open.
My 98 2,5L Boxster that i recently bought came with one problem.
When the top is open the windows will not totally close, they stay like when you begin to open the top.
When top is closed they work just fine.
Any help is welcome!!
HDman is offline   Reply With Quote
Old 11-24-2012, 02:16 PM   #2
thom4782's Avatar
On my 01S, after I unlatch the convertible top, the windows will drop down and stay down until the convertible top is fully open. While the top is partially open, I cannot raise the windows using the window switch.
There is a position sensor in one of the B pillars that tells the car whether the top is fully open. See this post
http://986forum.com/forums/general-discussions/24173-b-pillar-micro-switch-98661310102-a.html
Perhaps this sensor isn't working or the alignment has changed somehow.
My guess is the sensor does two things. It tells the motor to stop and it tells the light on the dash to go off. If both these things are happening, then I'm not sure where the problem might be.
Old 11-24-2012, 02:22 PM   #3
ccstud17's Avatar
in my 99, the switch is right where the hook goes into the latch above the rearview mirror, i solved it by adding a glob of silicon to the end of the "hook" which depresses the microswitch even further. lemme know if you need pics
ccstud17 is offline   Reply With Quote
Old 12-01-2012, 01:07 PM   #4
Thanks guys...i guess i will have to remove somehow the switch on the B-pillar so i can check if it is working.
