Old 11-24-2012, 09:19 AM   #1
ppbon's Avatar
My guess is that you have ....
.... a bad ignition switch.
The fact that the doors unlock when you activate the ignition is programmed into the Central Locking Unit (CLU). That can be modified with a PST-II, PIWIS or Durametric.
Happy Boxstering
Pedro
Originally Posted by Chuck937 View Post
Thx Thom4782...tried your suggestions....couldn't seem to get either door(s) to lock with just 1 door or both doors open. Here's what I did notice...with both doors closed and locking the doors with the center console switch, once I inserted the key into the ignition and turned to start position both doors unlocked.....and the hazard lights began flashing. I did check the hazard lights and they are working properly using the hazard switch.
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 11-24-2012, 09:23 AM   #2
thom4782's Avatar
When the horn beeps when locking the car using the remote key, does it beep once or twice?
