Old 11-17-2012, 05:24 AM   #1
Stan_D's Avatar
Water leak woes
Year 2000 Boxster - Trying to get to the bottom of water leaking from the rear water drip pan area into the interior. I have taken the water drip pan out - it has a minor tear from a "dangling" push rod, however could somebody please confirm...
Is water supposed to be able to get from the clamshell drain area into the water drip pan as shown in the picture? Will replacing the rubber seal fix this?
Thanks in advance.
Stan_D is offline   Reply With Quote
Old 06-08-2013, 04:49 AM   #2
What did you learn regarding the water leak? How did you fix the problem? I'm dealing with the similar issue with my 99 Boxster.
jccash is offline   Reply With Quote
Old 06-08-2013, 09:32 PM   #3
Nice photo. Better than a thousand words!
The rubber seal is just pressed onto where the two vertical sections of sheetmetal are welded together and normally comes sealed from the factory. If someone has pulled off that seal and the channel drain hole in that corner is overwhelmed by too much water, it will leak.
If you are getting water seeping in under the seal, just pull off the seal and apply some silicone adhesive caulk or sealant to the point where the two sections of sheet metal meet and halfway down (about 3/4 of an inch) each side of the two sections of sheetmetal before pressing the rubber seal back on.
That will seal the underside of the rubber seal to the sheetmetal.
Make sure that you tuck the front of the seal under that little pop-off piece of metal trim.
Regards, Maurice.
schoir is offline   Reply With Quote
Tags
water leak drip pan drain
