Old 10-09-2012, 02:34 PM   #1
Howling noise in 1st gear?
While coasting in 1st gear slowly today, I heard a slight howling noise. I'm not sure where it was coming from but when I clutched in, it went away. This is not the normal "transmission whine" that we hear from all Boxsters. Anyone have any ideas? The car still drove normal after.
ASpec818 is offline   Reply With Quote
Old 10-09-2012, 02:57 PM   #2
The first thing I would do is check or change the gear oil.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 10-09-2012, 04:24 PM   #3
Gear oil was changed about 5k ago. Is there an easier way to check the level besides undoing the fill plug?
Old 10-09-2012, 09:34 PM   #4
Not that I know of.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
Old 11-07-2012, 09:22 PM   #5
So I looked under the car and it appears that the transmission oil is leaking. I suspect it is very low. What are the chances that damage has been done? The car drove home fine in exception to the howling noise pulling out of the parking lot.
Old 11-08-2012, 03:22 AM   #6
That gearbox is pretty expensive, I would not be driving the car until you can have someone competent look at it...........
Old 11-08-2012, 04:58 AM   #7
Heiko's Avatar
+1 JFP in PA
1st and 2nd gear on the lower shaft are part of the drive shaft in the gear box and the
others float. If you leaked enough fluid to run these dry they will likely whine as any friction will transfer through the shaft. (The floating gears usually dont transfer noise as much)
I would check my tranny fluid before driving it any further, if you top it up and the noise is gone you might have caught it in time.
H
Previously owned:
