Old 07-28-2012, 02:56 PM   #1
Frunk courtesy lamp switch
I finally got around to replacing the courtesy light in my front trunk. The plastic housing had disintegrated.
Works great, but I am afraid it will wear down my battery if I can't locate the actuator (switch) and test it... And I can't find it!
My car is a 1997. Ideas?
Old 07-28-2012, 03:40 PM   #2
doragman's Avatar
intergrated into the front latch ..
'99 986 Baton Rouge, LA
doragman is offline   Reply With Quote
Old 07-28-2012, 07:35 PM   #3
WV Boxster
wvboxst3r's Avatar
If you have access to two iphones do face time call and put one in frunck and close it you should see the light go off.
If your not LIVIN now, then when?
wvboxst3r is offline   Reply With Quote
Old 07-28-2012, 07:40 PM   #4
KevinH1990's Avatar
You could also remove one of the headlights and peek in.
Old 07-28-2012, 08:39 PM   #5
Thanks guys! Great info and ideas!!!
Old 07-28-2012, 08:53 PM   #6
2003S's Avatar
Or if you just have one, take a video... :-)
2003 Midnight Blue S
LN IMS Retrofit
Old 07-29-2012, 07:06 AM   #7
Took both bulbs out (f & b) so not to worry about bulb heat and switch failure= dead battery.
milliemax is offline   Reply With Quote
Old 07-29-2012, 01:31 PM   #8
2003S, I did just what you recommended... shot a video and the light does go out.
Nice!
Old 07-29-2012, 01:48 PM   #9
in the old days they'd just put a kid up there...
SOLD - 2002 Boxster S - PSM, Litronics, De-ambered, Bird Bike Rack, Hardtop, RMS leak...
fatmike is offline   Reply With Quote
Old 07-29-2012, 02:04 PM   #10
doragman's Avatar
So right fatmike ...so right !!
